Please help with question 'copy tftp flash'
news2010a
Level 3
Level 3
Hi, I am getting a time out when trying to copy tftp flash. If the remote tftp server requires authentication (I suspect that is the problem but I am not sure), is there any way to get authenticated first then do 'copy tftp flash' to avoid the error below? Please see ouput below showing that I have connectvity to tftp server just fine.
ciscoswitch#copy tftp flash
Address or name of remote host []? 10.1.1.1
Source filename []? c2950-i6k2l2q4-mz.121-22.EA13.bin
Destination filename [c2950-i6k2l2q4-mz.121-22.EA13.bin]?
Accessing tftp://10.1.1.1/c2950-i6k2l2q4-mz.121-22.EA13.bin...
%Error opening tftp://10.1.1.1/c2950-i6k2l2q4-mz.121-22.EA13.bin (Timed out)
ciscoswitch#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
On 10.1.1.1:
/tftpboot
unixtftp# ls -l
total 35354
-rw-r--r-- 1 root root 3721946 Jul 10 13:23 c2950-i6k2l2q4-mz.121-22.EA13.bin
unixtftp#
Jerry Ye
Hi Marlon,
What is the permission on /tftpboot? I don't believe there is any option to specify tftp with authentication.
HTH,
jerry
Jerry Ye
Hi Marlon,
HTH,
jerry
Thanks! I had to fix permissions on the Unix host.
