Pls Help me, C.4948E modify TCAM size
JONGKWONKIM0912
How can i increase TCAM Output Security size 6144 to 8192?
Once i have to changed 2048 to 6144 but now i can't remember the command.
(WS-4948E, cat4500e-ENTSERVICESK9-M, 15.0(2)SG6)
Please let me know how can i change it!
ーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーー
web_4948E#sh platform hardware acl statistics utilization brief
CAM Utilization Statistics
Used Free Total
Input Security (160) 32 (1 %) 2016 (99 %) 2048
Input Security (320) 38 (1 %) 2010 (99 %) 2048
Input Forwarding (160) 7 (0 %) 2041 (100%) 2048
Input Forwarding (320) 24 (1 %) 2024 (99 %) 2048
Input Unallocated (160) 0 (0 %) 24576 (100%) 24576
Output Security (160) 2804 (45 %) 3340 (55 %) 6144
Output Security (320) 12 (0 %) 2036 (100%) 2048
Output Qos (160) 23 (1 %) 2025 (99 %) 2048
Output Qos (320) 4 (0 %) 2044 (100%) 2048
Output Unallocated (160) 0 (0 %) 20480 (100%) 20480
Input Profiles (logical) : used 1 / 32
Input Profiles (physical): used 4 / 32
Output Profiles (logical) : used 1 / 32
Output Profiles (physical): used 3 / 32
web_4948E#
Giuseppe Larosa
Hello Jong,
have a look at the following document
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/15-02SG/configuration/guide/config/secure.html#88478
The command should be:
access-list hardware region feature + other parameters
in global config
Hope to help
Giuseppe
Thank you, Giuseppe.
I try to input 'access-list hardware region feature + other parameters' in global config
but there's no command 'ccess-list hardware region'.
web_4948E(config)#access-list hardware ?
capture Determine how to capture certain control packets
Can i allocate from Output Unallocated 20480 to Output Security, directly. (2048 or 1024, or 4096, not balance)
Hello Jong,
a more recent configuration guide is here
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-8-0E/15-24E/configuration/guide/xe-380-configuration/secure.html#47441
However, I cannot find the new commands for TCAM sizing.
I am searching in it.
The command that you have found can be used only for troubleshooting by performing capture of packets sent to the main cpu. It is a different feature.
Hope to help
Giuseppe
