POE not working on all ports for 2960s switch.
MOHD SYAFIQ
I have a  POE issue not working. I see this message in the log before my AP disassociated.
"Nov  4 05:19:48: %HARDWARE-3-MCU_I2C_READ_ERROR: I2C read failed in MCU and attached devices (e.g. Temperature Sensor) can't be read."
Here is the output of "show power inline"
IBHQSWCL20A1#sh power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           370.0       53.2       316.8
2           370.0       30.8       339.2
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/1   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/2   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/3   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/4   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/5   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/6   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/7   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/8   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/9   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/10  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/11  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/12  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/13  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/14  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/15  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/16  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/17  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/18  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/19  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/20  auto   on         7.0     Ieee PD             2     30.0
Gi1/0/21  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/22  auto   on         15.4    Ieee PD             3     30.0
Gi1/0/23  auto   on         15.4    Ieee PD             3     30.0
Gi1/0/24  auto   on         15.4    Ieee PD             3     30.0
Gi2/0/1   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/2   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/3   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/4   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/5   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/6   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/7   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/8   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/9   auto   off        0.0     n/a                 n/a   30.0
Gi2/0/10  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/11  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/12  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/13  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/14  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/15  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/16  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/17  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/18  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/19  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/20  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/21  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/22  auto   on         15.4    AIR-LAP1142N-C-K9   3     30.0
Gi2/0/23  auto   off        0.0     n/a                 n/a   30.0
Gi2/0/24  auto   on         15.4    AIR-LAP1142N-C-K9   3     30.0
IBHQSWCL20A1#
As you can see, for interface Gi1/0/22-24, the device shown there are IEEE PD. After I shut and no shut the port, switch didn't detect any device. Then I connect the 3 APs to secondary switch for temporary.
How to solve this?
Syafiq
devils_advocate
Level 7
Level 7
Have you tried a different port?
Tried plugging the AP straight into the switch with a short patch cable to rule out a structured cable issue?
Tried rebooting the switch?
8 Replies 8
devils_advocate
Level 7
Level 7
---> Yes
---> Yes, I plug AP to the switch directly but not powered up. Then I connect to secondary switch, all three APs up.
---> Not yet. I will reboot this Saturday after IOS upgrade.
If the problem not resolve after reboot and upgrade, do I need to replace the switch?
Syafiq
The problem solved by power cycle the switch. Reload command didn't solve it.
This article is helpful
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html
Anyway, thanks for your advice. Have a nice day.
Syafiq
Do the issue happen again after you power cycle this switch?
Best Regards,
Jackson
Hi Jackson,
Since I'm not the resident engineer for that customer since 2015, I dont know whether the issue occurs again. But as for last time, power cycle the switch solved the problem.
Syafiq
Got it, thanks a lot.
Hello Mohd Syafiq
How did you do the the power cycle. Is it like resetting the switch to default settings or?
Is a hardware issue follow the link below to solve it .
https://youtu.be/zGdYVwBtMPU?si=XRLxFLbXRQWxrgdX
