POE Question for WS-C3650-48PS
FAQ document for Cisco Catalyst 3650 Series Switches indicates for all POE PID's on this model full poe is attainable either by 2 power 640VAC supplies or one large 1025 VAC.
Q. Can the PoE budget of Cisco Catalyst 3650 switch be increased by replacing its power supply with a
high-capacity power supply?
A. Yes, the available PoE budget of a Cisco Catalyst 3650 PoE switch can be increased by either replacing its power supply with a higher capacity one or adding a second PoE power supply model (640W or 1025W).
We have WS-C3650-48PS with 1 640W power supply,  Vendor indicates this model can not achieve full Poe with second power supply 15.4 across 48 ports?  They are insisting on returning this model WS-C3650-48PS and replace with WS-C3650-48FS with 1 1025W?
I am very confused as they said the internals of the switch models are different ?  Does any one have a WS-C3650-48PS with 2 640 PS or 1 1025  and can show  "sh power inline" ?
In most all my experience most switches add to the POE budget with second power supply just how the Cisco FAQ explains this.
According to Cisco FAQ " Cisco Catalyst 3650 Series Switches" page 4 Table 4 it states all POE PID's cabable of Full POE.
Francesco Molino
With 2 power supply it should be ok.
Take a look on Cisco power calculator tool: http://cpc.cloudapps.cisco.com/cpc/PDS.cpc
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
This is correct. Cisco indicated the PoE budget increases with second power supply across all PIDs. The 3650-48PF is a default PID "purchase with FULL PoE on 1 single Power supply.
Second check according to the PoE calculator - shows what the potential PoE budget is if one is to purchase a second Power supply for PID --> WS-C3650-48PS.
Thank you,
Mike
Leo Laohoo
The vendor is telling the truth.
If you want 15.4w to all 48-ports then the switch model to use is 3650-48PF.
