Policy Base routing not working
lmanavalan
i have configured the policy based routing on cisco ASR1001 which is running on IOS asr1001-universalk9.03.06.00.S.152-2.S.bin. which is having issues.
This router is transit router and this router learning specific routes (few /29s) on one interface and /24 route on another interface.
i have configured the policy route for the transit traffic to have the next-hop pointing the interface where /24 route is learn from but its not working.
i have configured the policy to match the route-map which follows the access-list.
But i done see any hits on the access-list.
is there any known issue with this version of code.
regrads
Logesh
Julio Carvajal
Your message is not clear!
Try it one more time plus share the configuration you have.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2-CCNP, JNCIS-SEC
For inmediate assistance hire us at http://i-networks.us
Julio Carvajal
CCIE #42930, 2xCCNP, JNCIP-SEC
Nikhil Kapoor
Hi Iman,
To isolate the issue you could run "debug ip packet". I would suggest below.
- Make an access-list define source and destination
- no logging console >> This will not shoot the CPU incase for debug.
- Enable debug on the router " debug ip packet <access-list>
From the debug you would come to know why packet is being dropped and how it is treated.
Also please run above plan of action if you are sure that your configuration is fine and you suspect that router is behaving weird and not doing its job which it is supposed to do.
Please run debug in controlled condition , Maintenance window.
HTH,
Nikhil
