Policy based routing and Floating routes
imranraheel
I have following configurations in one router and i am not been able to fetch the details thay y are they used. kindly suggest me some link or info regarding this
rtr 1
type echo protocol ipicmpecho 192.168.52.34
rtr schedule 1 life forever start-time now
track 192 rtr 1 reachability
int x
ip policy route-map ABC_MAP
route-map MIXIT_MAP
set ip next-hop verify-availability 192.168.52.34 10 track 192
ip route xx.xx.xx.241 255.255.255.255 192.168.52.34 track 192
ip route xx.xx.xx.241 255.255.255.255 ABC_INTERNET_INTERFACE 254
Yes, there's no drawback. As soon as 192.168.52.34 becomes reachable the primary route will be used.
All it's doing is the router would remove the route to xx.xx.xx.241 via 192.168.52.34 if the next hop is unreachable and it would start using the route to xx.xx.xx.241 via ABC_INTERNET_INTERFACE. You can read up more on this feature here.
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Sundar
Is there any draw back will I be able to get the route back if i will get the connectivity back to xx.xx.xx.241 via 192.168.52.34
I am trying to implemet the following configurations
rtr 1
int x
route-map ABC_MAP
ip route xx.xx.xx.241 255.255.255.255 xx.xx.xx.2 254
But when ever i try this i receive an error (command support issues)on verify-availability
I am using 3550 with (C3550-IPSERVICESK9-M), Version 12.2(35)SE IOS.
Kindly put some light on this
