Policy-Based Routing - Cisco 1811
OSJF2009SDL
I have two Cisco 1811 routers, each router has a WAN connection and at least one local subnet connected.
Router #A
IF_WAN          IP_ISP_A
IF_VLAN01     10.10.10.1
IF_VLAN02     10.10.11.1
IF_VLAN03     192.168.7.252
Router #B
IF_WAN         IP_ISP_B
IF_VLAN04     192.168.7.254
I need to re-route traffic from IF_VLAN02 to use IP_ISP_B to connect to the internet.
I created an ACL
ip access-list extended reroutetest
permit ip 10.10.11.0 0.0.0.255 any
A route-map
route-map reroutetest permit 10
match ip address reroutetest
set ip next-hop 192.168.7.254
and assigned the route-map to IF_VLAN02
interface vlan 108
ip policy route-map reroutetest
On router #B i created a static route and added a NAT rule so that the packets find their way back to router #A
From a client on the subnet I need to re-route (IF_VLAN02) I run a tracert to google DNS server.
Tracing route to 8.8.8.8 over a maximum of 30 hops
1     7ms     3ms     <1ms     10.10.11.1
2     1ms     <1ms    <1ms     192.168.7.254
3     *       *       *        *
4     25ms    25ms    25ms     8.8.8.8
So it seems to work fine. However, at this point I cannot connect from IF_VLAN02 to IF_VLAN01 anymore.
How can I reroute IF_VLAN02 traffic without loosing connectivity to IF_VLAN01?
router #a config is attached to this post Any help would be greatly appreciated!
regards
Sebastian
Giuseppe Larosa
Hello Sebastian,
you need a line to deny = do not apply PBR for inter vlan routing
something like:
deny ip 10.10.11.0 0.0.0.255 10.10.10.0 0.0.0.255
traffic denied will be routed normally that is what you want to do
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sebastian,
something like:
Hope to help
Giuseppe
Hello giuslar,
I tried that before but there must have been a typo somewhere. It works fine now!
Thank You!
