Policy-Based Routing Question
msrohman
Hi all,
I applied a basic policy-map to a 6513 L3 switch today. I'm routing two users over another path for User-Acceptance-Testing. The policy map works. The users were able to trace-route to the destination. The source IP addresses in the access-list are getting routed using the next-hop in the route-map statement.
However, I don't see any counters increasing when I perform a 'show route-map' command. Am I missing something?
The config and show command is below:
route-map fact-set-test-user permit 10
match ip address 101
set ip next-hop 172.30.1.2
access-list 101 permit ip host 172.30.20.3 164.55.2.0 0.0.0.255
access-list 101 permit ip host 172.30.20.3 164.55.3.0 0.0.0.255
access-list 101 permit ip host 172.30.20.60 164.55.2.0 0.0.0.255
access-list 101 permit ip host 172.30.20.60 164.55.3.0 0.0.0.255
access-list 101 permit ip host 172.30.20.3 164.55.4.0 0.0.0.255
access-list 101 permit ip host 172.30.20.60 164.55.4.0 0.0.0.255
interface Vlan8
ip policy route-map fact-set-test-user
MSFC1#sh route-map
route-map fact-set-test-user, permit, sequence 10
Match clauses:
ip address (access-lists): 101
Set clauses:
Policy routing matches: 0 packets, 0 bytes
Thanks for your help
-Mike
Jon Marshall
Mike
An educated guess would be that PBR is performed in hardware on the 6500 ie. it is done by the PFC (Policy Feature Card). Because it is done in hardware the counters are not incremented.
This is definitely the case for acl's performed in hardware ie. no counters incremented so it would seem logical that is what is happening here.
Jon
Do you hit counts on the ACL's? If so than that should tell you that your PBR is matching and working.
kishan1984
In tracert output did you see the hop 172.30.1.2 set by you,if yes than it is working fine,and counters are not incrementing because it will increase only if processed by switch/Router cpu.
