Policy Based Routing
dpatkins
Good afternoon,
I have configured two route maps that I will assign to different interfaces. I am testing with a Cisco 4506 loaded with Version 12.2(37)SG. When I go to assign the route-map to a particular interface, I complete the following commands:
conf t
int gig2/6
and there is no command for ip policy route-map map-tag.
Is there something I am missing on a 4506? It is Cisco IOS version.
Thank you.
Dwane
12 Replies 12
Jon Marshall
Dwane
Have you configured the interfaces as layer 3 routed interfaces ie.
conf t
int gi2/6
no switchport
If the interfaces are layer 2 switchports which they are by default then the "ip policy ..." command will not be available.
Jon
Jon,
Thanks for the quick response, but I have an ip address on that interface.
interface GigabitEthernet2/6
description test HRC to ERC
no switchport
ip address 192.168.254.1 255.255.255.248
spanning-tree portfast
interface Vlan503
ip address 10.101.254.254 255.255.255.128
ip helper-address 129.111.26.6
ip helper-address 129.111.26.7
no ip redirects
ip route-cache same-interface
no ip route-cache cef
no ip route-cache
These are the two interfaces I would like to assign the Route-maps.
This is weird.
THanks
Dwane
Dwane
Just checked Feature Navigator. IP base image does not support PBR. For PBR you need Enterprise Services.
Which feature set do you have ?
Jon
Jon,
That is what we thought until we went out and read the Guide for 12.2.37 SG and it showed us exactly how to do this? How the heck can you offer up the ability to do route-maps and not the ability to assign the route-maps?
It is the IP based image. cat4500-IPBASEK9-M
Dwane
My apologies. I said "how can you offer" when I meant how can Cisco offer the ability to create route-maps and not the ability to assign them? Weird. I will look at upgrading. Can you send me the link that you were refering to for the feature sets?
Thanks again for all your help.
Dwane
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Search by Platform and then in the drop down box ignore the CatOS entries at the top and scroll down to the 4500 entires under IOS.
I guess the thinking is route-maps can be used for other things than just PBR so you may need them in the IP Base image.
Jon
You need a SupIV or better for PBR. If you are running SupII, it won't support that feature.
HTH,
__
Edison.
Edison,
Here is our sup for this switch:
1 2 Supervisor IV 1000BaseX (GBIC) WS-X4515 JAE1118FGLD
is our Sup.
This is odd.
Dwane
dpatkins
Edison and Jon,
I think Jon hit right on the head with the PBR not being supported in the IP BASIC IOS. IT is supported in the enterprise version. I am sitll not sure why Cisco would offer the route-map capability with the the ability to assign the route-map to an interface.
THis is all too weird.
Thanks for your help. Great Job. Thanks for the advice.
Dwane
route-map is not only for PBR. You can use route-map for route distribution.
for instance,
router rip
redistribute connected metric 1 route-map test
HTH,
__
Edison.
Edison,
Thank you.
Please view this link for the necessary explanation.
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcpolicy.html
Thanks but I think it is actually an issue with the version I am running. I will acke it on Monday. Have a great weekend and thanks for everyone's help.
Dwane
Dwane
Yes, I know the version you are running isn't capable of supporting PBR. I was merely pointing out the fact that you can use route-map (which is a component of PBR) for other purposes.
The key command for PBR is ip policy route-map.
