policy-map Issue
G3000LEE
WS-C3650-12X48UR-E
Software Version: 16.9.4
The issue is related to the application of a new policy-map and it not been hit. The switch config is show below:
class-map match-all CTS
match access-group name CTS
class-map match-all PACEY
match access-group name PACEY
policy-map customer_vsx_bandwidth_limit
class CTS
 police cir 350000000 bc 175000
  conform-action transmit
  violate-action drop
class PACEY
 police cir 30000000 bc 5625000
  violate-action drop
class class-default
policy-map customer_allocated_vsx
class class-default
 bandwidth percent 100
 queue-buffers ratio 100
  service-policy customer_vsx_bandwidth_limit
policy-map default_buffer_que
class class-default
ip access-list extended CTS
permit ip any x.x.x.x x.x.x.x
permit ip x.x.x.x x.x.x.x any
deny  ip any any
ip access-list extended PACEY
permit ip any host x.x.x.x
permit ip host x.x.x.x any
deny  ip any any
(access list IP details hidden but set up with the correct addresses)
The new config is highlighted in bold.
The below show the PACEY map is not been hit but CTS is
TFM20-DIST-3650-B#show policy-map interface gi1/0/17
GigabitEthernet1/0/17
 Service-policy output: customer_allocated_vsx
   Class-map: class-default (match-any)
     6494049035 packets
     Match: any
     Queueing
     (total drops) 30174599
     (bytes output) 4617005411418
     bandwidth 100% (1000000 kbps)
     Service-policy : customer_vsx_bandwidth_limit
       Class-map: CTS (match-all)
         6487482186 packets
         Match: access-group name CTS
         police:
             cir 350000000 bps, bc 175000 bytes, be 175000 bytes
           conformed 3339873693272 bytes; actions:
             transmit
           exceeded 102268355219 bytes; actions:
             drop
           violated 0 bytes; actions:
             drop
           conformed 39460000 bps, exceeded 509000 bps, violated 0000 bps
       Class-map: PACEY (match-all)
         0 packets
         Match: access-group name PACEY
         police:
             cir 30000000 bps, bc 5625000 bytes, be 5625000 bytes
           conformed 0 bytes; actions:
             transmit
           exceeded 0 bytes; actions:
             drop
             drop
           conformed 0000 bps, exceeded 0000 bps, violated 0000 bps
         6566849 packets
         Match: any
Any help would be appreciated
I also lab it on a router and it's working but not on a switch. This is an issue with a customer so there must be something they're not doing right or a bug.
I have access to just about every bit of hardware, so I will lab it up on the same switch and software to see if I get the same result
pman
Did you make sure that the source ip that configured in PACEY ACL actually transmits data through GigabitEthernet1/0/17 in out direction?
i have checked it and i got hits:
Router#show policy-map interface gigabitEthernet 0/2 | b PACEY
1363 packets, 154937 bytes
5 minute offered rate 5000 bps, drop rate 0000 bps
police:
conformed 1363 packets, 154937 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
violated 0 packets, 0 bytes; actions:
drop
conformed 5000 bps, exceeded 0000 bps, violated 0000 bps
3698 packets, 418292 bytes
Match: any
we have merged these into one policy by creating a single ‘service-policy output customer_allocated_vsx’, in which that policy is a Parent/Child QOS setup?
So we now have policy map ‘customer_allocated_vsx’ as the PARENT which has policy map ‘customer_vsx_bandwidth_limit’ as the CHILD containing the two classes (CTS and PACEY)
class CTS
  violate-action drop
class PACEY
  violate-action drop
class class-default
class class-default
class class-default
interface GigabitEthernet1/0/17
description XXXXXX ETH3
switchport trunk allowed vlan 513
switchport mode trunk
switchport nonegotiate
load-interval 30
no cdp enable
no snmp trap link-status
spanning-tree portfast trunk
spanning-tree bpduguard enable
end
Can you please get them to clarify why this Parent/Child relationship is not correct/working and provide a quick example of how it should be created?
Yes, it has been tested but now the Policy config has changed and I have updated the post.
