policy-map not matching DSCP EF
Oerlikon_NZ
As a test I have enabled a policy-map PM-QOS-LAN on my switch VLAN 'LAN' interface to match packets based on ACL, and set DSCP EF.  I can see matches for this policy-map.  However when I enable another policy-map PM-QOS-WAN on my switch VLAN 'WAN' interface to match for DSCP EF I can't see any matches.
I can't see what I am doing wrong.  Can anyone help thanks?
## Classify traffic & set DSCP EF
ip access-list extended ACL-QOS-LAN
remark Classify traffic
10 permit ip 192.168.16.0 0.0.0.255 192.168.8.0 0.0.0.255
class-map match-any CM-QOS-LAN
  match access-group name ACL-QOS
  class CM-QOS
   set dscp ef
interface vlan 21
description Local Hosts
ip vrf forwarding Test
ip address 192.168.16.254 255.255.255.0
service-policy input PM-QOS-LAN
ip route vrf Test 192.168.8.0 255.255.255.0 192.168.64.1
R1#show policy-map interface vlan 21
Vlan21
  Service-policy input: PM-QOS-LAN
    Class-map: CM-QOS-LAN (match-any)
      724644 packets
      Match: access-group name ACL-QOS-LAN
        724644 packets
      QoS Set
       ip dscp ef
    Class-map: class-default (match-any)
      6586885 packets
      Match: any
## See if classification is working
class-map match-any CM-QOS-WAN
  match ip dscp ef
  class CM-QOS-WAN
interface vlan 11
description WAN
ip address 192.168.64.2 255.255.255.252
service-policy input PM-QOS-WAN
service-policy output PM-QOS-WAN
R1#sh policy-map interface vlan 11
Vlan11
  Service-policy input: PM-QOS-WAN
    Class-map: CM-QOS-WAN (match-any)
      0 packets
      Match: ip dscp ef
        0 packets
      9734258 packets
      Match: any
  Service-policy output: PM-QOS-WAN
      0 packets
      Match: ip dscp ef
        0 packets
      6536248 packets
      Match: any
  class CM-QOS
   set dscp ef
interface vlan 21
Vlan21
      724644 packets
        724644 packets
      QoS Set
       ip dscp ef
      6586885 packets
      Match: any
  match ip dscp ef
  class CM-QOS-WAN
interface vlan 11
description WAN
Vlan11
      0 packets
      Match: ip dscp ef
        0 packets
      9734258 packets
      Match: any
      0 packets
      Match: ip dscp ef
        0 packets
      6536248 packets
      Match: any
Oerlikon_NZ
Well I'm not sure why I'm not matching packets for DSCP on the switch WAN interface, but I've enabled an identical policy map on the WAN interface of the next hop device and I can see packets being matched just fine.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Switches?  Often policy-maps are very restricted on switches vs. software routers.
