Port-based and MAC-based DHCP for Cisco 2960 & 3560
omar.robles
I want to implement port-based and MAC-based in these two switches: 2960 & 3560 (both of them have this IOS version: 12.2(55)SE1). And I haven't found a way to implement both of them at the same time. This is what I got:
ip dhcp use subscriber-id client-id
ip dhcp subscriber-id interface-name
ip dhcp excluded-address 192.168.0.0 192.168.0.2
ip dhcp excluded-address 192.168.0.251 192.168.0.255
ip dhcp pool Test_Pool
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.2
   option 150 ip 192.168.0.1
   lease 7
   address 192.168.0.250 client-id "Fa0/4" ascii
   address 192.168.0.4 client-id "Fa0/3" ascii
   address 192.168.0.7 hardware-address 12ae.1daf.5860
With this configuration I can use port-based, but not MAC based.
If I remove the first two lines and change the last line for this one:
address 192.168.0.7 client-id 0112.ae1d.af58.60
Then, the computer with that MAC address got the correct IP, but then the port-based doesn't work.
Also, I got this line in the interface what I want to use MAC-based:
ip dhcp server use subscriber-id client-id
Please, if you guys know what to do let me know. I've tried a lot of things, and nothing is working.
omar.robles
Anyone? any clue?
Hi Omar,
I've got a similar problem so I associate my question to your thread.
First, refferring to your question, what should happen if host with MAC=12ae.1daf.5860 is connected to Fa0/4?
In this case switch doesn't know which address assign to client unless switch has some kind of default priority.
My problem is somehow similar.
I want to have Port-Based feature configured on some ports only.
But no  matter what commands I try. It seems that this can only be done for all  ports or for none.
Even though CISCO manual seems to indicate there's  both global and per-port command to enable that. Here are relevant commands from CISCO manual:
  • ip dhcp use subscriber-id client-id
    (this configures the DHCP server to globally use the subscriber ID as the client ID on all incoming DHCP messages)
  • interface FastEthernet0/1
  • ip dhcp server use subscriber-id
    client-id
    (Optional: Configures the     DHCP server to use the subscriber ID     as the client ID on all incoming DHCP    messages on the interface)
If I configure only per-interface it appears there's no  effect at all.
If I configure globally and per interface, switch behaves  as if all ports were configured to use that feature.
What's the issue?
Thank you.
Hi Alberto,
If I plugged in the host with that MAC into port F0/4 it will automatically gets the 192.168.0.250 address.
Looks like the problem is this command: ip dhcp server use subscriber-id client-id
Doesn't have any effect in the interface.
