Port channel bandwidth on Nexus 9K
war202994
Good Morning
I had a quick question and I am probably looking in the wrong place but wasn't able to find any docs on this
but I have 2 10 gig interfaces that I combined into a port channel I would assume that the speed shown would be
20Gbps but when I look at them the speed is 10Gbps.  Is this by design or am I configuring something wrong?
This is on a Nexus 9k C93108TC-EX chassis
Po2 Xconnect  connected trunk full 10G --
interface port-channel2
description Xconnect
switchport
switchport mode trunk
Eth1/45 Xconnect connected trunk full 10G 10g
Eth1/46  Xconnect connected trunk full 10G 10g
interface Ethernet1/45
switchport
logging event port link-status
channel-group 2
no shutdown
interface Ethernet1/46
switchport
channel-group 2
no shutdown
"sh inter statu" will only show you the speed of the physical interface which is 10Gig and not the aggregate bandwidth.
That is the case with different platforms.
5 Replies 5
Reza Sharifi
Try "sh int po2"
you should see something like this:
BW 20000000 Kbit/sec, DLY 10 usec
Hi Reza
Yes I do see it at 20Gbps when I do as you mention sh int po2 , question is why when I do "sh inter statu" PO2 says 10gig instead of
20 would you happen to know or lead me to documentation as to why this is?
port-channel2 is up
admin state is up,
Hardware: Port-Channel, address: 0027.e36a.c4de (bia 0027.e36a.c4de)
Description: X to sf6landswa144ha1
MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec
Thank you sir!!
oh ok makes sense thank you sir!!
Anytime. Glad to help!
