I've 2 x sg350x-12pmv switches i'm configuring for a datacentre.
They are fully configured and working
Problem is i've configured the management vlan on ports 1 and 11
If i boot the switch and it comes online, port 11 will not work with a direct cable for access on both switches
auto smartport has been disabled.
This is a POE port
Ports 5-12 are poe
I think this is a flaw in it's design.
As i've asked cisco for a solution and all they came back with was to wipe the switch and configure it manually to see if it occurs and it does.
