Port Channel Configuration between Cat 6500 & Juniper Firewall
edmond.chiu
Can anyone advise what is the best practice for the port Channel connection between Cat 6500 and Juniper firewall. Do I use PAGP or LACP, Does Juniper firewall support PAGP?
Any feedback is welcome.
Collin Clark
Junipers don't support PaGP, so you'll have to use LACP.
You can get Netscreen configuration guides at http://www.juniper.net/techpubs/software/screenos/screenos6.2.0/index.html
Hope that helps.
