Port Channel Routing
zekebashi
Level 4
Level 4
I created L3 port channels on both the ASR and the 4500(core). Connect one port on the ASR and one on the 4500. Those ports are up/up but the Po1 on both the ASR and C4500 are down.  What am I missing?
ASR
interface Port-channel1
description Link to DO-Core-01 Po1 Te1/14 & Te1/15
ip address 10.35.1.25 255.255.255.0
no negotiation auto
interface Port-channel2
description Link to PA_FW
ip address 10.35.2.1 255.255.255.0
shutdown
no negotiation auto
interface GigabitEthernet0/0/0
description Member of Po1
no ip address
negotiation auto
channel-group 1 mode passive
interface GigabitEthernet0/0/1
no ip address
negotiation auto
Core
description Link to DO-ASR-01 G0/0/0 & G0/0/1
ip address 10.35.1.1 255.255.255.0
DO-Core-01#sh run int te1/14
Building configuration...
Current configuration : 160 bytes
interface TenGigabitEthernet1/14
description Member of Po1 Link to DO-ASR-01 Po1 G0/0/0 & G0/0/1
no switchport
no ip address
channel-group 1 mode on
end
DO-Core-01#sh run int te1/15
interface TenGigabitEthernet1/15
no switchport
no ip address
end
Philip D'Ath
"passive" means only do a channel if the other end asks.  "on" means don't ask, just channel.
Use "active" on both ends.  This enables LACP, which is also supported across chassis.
Philip D'Ath
That worked.
Thanks, P!
