port-channel to Netgear Switch
S891
Level 2
Level 2
I have setup port-channel to Netgear switch. The port-channel is setup on LACP and ports are UP. The trunking is also working and I can communicate on the VLANs. The issue I am seeing is the port-channel  ports are not (P) but (I). It means the port are not bundled but they're stand-alone. I have tried changing the mode Active and Passive but it is still the same state. Not sure what the issue is! Any ideas?
Group  Port-channel  Protocol    Ports
1      Po1(SD)         LACP      Gi1/16(I)      Gi1/46(I)
2      Po2(SD)         LACP      Gi1/37(I)      Gi1/38(I)
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
amikat
Can you please check your Netgear switch is configured to LACP LAG, ie. not static (indicated by: "static mode disabled" or "LACP up" or "LAG type LACP" depending on the switch type).
Best regards,
Antonin
