port channel trunk
Mary
I want to build a  etherchannel 3 for int g1/1 and g1/2, g1/1 is connected to ucs. so int po3 configuration, I should use
 switchport  access vlan 111 or switch trunk allowed vlan 111 assuming vlan 111 is created for UCS
or should i use L3 port channel and define ip address, when should we use L3 channel?
Jon Marshall
If you only need a single vlan on the etherchannel then do that. If you need multiple vlans across the etherchannel then use a trunk.
A L3 etherchannel is used when there are L3 devices at either end of the etherchannel. They are not used to extend vlans between devices.
Jon
L3 devices means router only?
No, it can mean a L3 switch or any L3 capable device.
Jon
