Port forwarding for the Web server for outside Internet (not working , help!!!!!!)
said.ritel
Hello
I am trying to learn something new here. We have web server inside our organization its IP address is 172.16.0.35. We want outside Internet users to access web server, How is it possible? Please have a look at the running configuration. Web server is working inside the organization but not at outside. Our Static Public IP is 197.255.232.15 it is assigned to Inetrface Gigabit ATM0.1  and ISP default GW is 197.255.232.1. Let me know whats next? How do I make web server inside the organization available for outside Internet users. Thank you.
Building configuration.
Current configuration : 1983 bytes
! Last configuration change at 17:57:15 UTC Sat Jan 24 2015
version 15.2
no service pad
hostname router_test
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 172.16.0.34
ip dhcp pool test
 network 172.16.0.32 255.255.255.224
 dns-server 197.255.224.18 197.255.224.66
 default-router 172.16.0.34
 lease 9
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FGL1818236L
controller VDSL 0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description ATM Routed Bridge Encapsulation (RBE) Internet
 ip address 197.255.232.15 255.255.248.0
 ip access-group netin in
 ip access-group netout out
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 atm route-bridged ip
 bridge-group 1
 bridge-group 1 spanning-disabled
 pvc 0/35
  encapsulation aal5snap
  protocol ip inarp
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 description Lan
 ip address 172.16.0.34 255.255.255.224
 ip nat inside
 ip tcp adjust-mss 1454
interface Dialer1
 no ip address
ip default-gateway 197.255.232.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list natlist interface ATM0.1 overload
ip nat inside source static tcp 172.16.0.35 443 197.255.232.15 443 extendable
ip route 0.0.0.0 0.0.0.0 ATM0.1 197.255.232.1
ip access-list extended natlist
 permit ip 172.16.0.32 0.0.0.31 any
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
http://pastie.org/9858814
On your public interface you have ACLs "natin" and "natout". What is in these ACLs? They should allow the needed web-traffic.
said.ritel
Hi  Karsten Iwen
I deleted ( ip access-group netin in and ip access-group netout out) but it still does not work
my config :
Building configuration...
Current configuration : 2267 bytes
! Last configuration change at 15:43:06 UTC Wed Jan 28 2015
version 15.2
no service pad
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool my
 lease 9
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 no ip virtual-reassembly in
 pvc 0/35
  no protocol ip inarp
 no ip address
 no ip address
 no ip address
 no ip address
interface Vlan1
 description
 ip nat inside
 ip tcp adjust-mss 1414
interface Dialer1
 no ip address
no ip http server
line con 0
 no modem enable
line aux 0
line vty 0 4
end
Router#sh ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
tcp 197.255.232.15:5183   172.16.0.33:5183      212.95.74.5:80        212.95.74.5:80
tcp 197.255.232.15:5196   172.16.0.33:5196      212.95.74.5:80        212.95.74.5:80
tcp 197.255.232.15:5602   172.16.0.33:5602      174.129.246.27:80     174.129.246.27:80
tcp 197.255.232.15:5785   172.16.0.33:5785      31.13.93.3:443        31.13.93.3:443
tcp 197.255.232.15:443    172.16.0.35:443       ---                   ---
