Port Management 2960-x can't ping
pechdara pin
Hi guy, I have an issue regarding to port management of switch cisco 2960-x.
the issue is when i connect from port management to switch port itself, and the i plug
from switch to my computer, so I can't ping. But when i plug port management to other
switch else, i can ping normally. I thought should have a command line to enable something
behind, if we want to connect port management and plug it into its own port switch.
I hope you guy can help me. Thank.
Reza Sharifi
You are not supposed to plug the management port to its own port.  The management port is for out-of-band management and it should be plugged into a different switch. So, the behavior you are seeing is correct.
