Port Mirror (SPAN) in Packet Tracer
roadstone
Hi all,
I've got a little test network configured in Packet Tracer. I'm trying to enabled monitoring on a 3650 switch interface, but keep getting an error when defining port source or destination interfaces (although it does accept a VLAN interface as a source). Whilst it may be the command I'm entering, I am a little lost as to why it fails.
core-01(config)#monitor session 1 source interface GigabitEthernet 1/0/1 both
% Invalid input detected at '^' marker.
(NOTE: The ^ sits under the /0/)
If I step through the command using ? when I get to the interface, it does suggest it wants a format of slot/port. But any other combination seems to fail with a range error. I've seen a couple posts where people have mentioned monitor was not fully functional in Packet Tracer, but guessing it could just be an error with my input. Any help appreciated?
Rob
7 Replies 7
Abheesh Kumar
which version of packet tracer you are using. Command is working in version 7.1.0.
Abheesh
Hi Abheesh,
I'm currently running v. 7.2.0.0226.
where do you get GigabitEthernet1/0/1 ? The 3650 in PT only has GigabitEthernet0/0 and 0/1. It is not a modular switch. So the below should work:
Switch(config)#monitor session 1 source interface gigabitEthernet 0/1
Hi Georg,
I tried that and I received the "interface range not validated - command rejected".
A "show ver" reports the switch as a WS-C3650-24PS with interfaces as follows in the sh run...
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
etc.
Try on version 7.1, may be issue with the software version
Abheesh
Hi Abheesh,
Thanks for the tip. I installed 7.1 and was still unable to get it configured on the 3650. That being said, for my testing purposes I've switched the 3650 out with a 3560, and am able to configuring span as required. All working!
Many thanks,
Rob
It may be the packet tracer issue that not supports in 3650.
