port priority
robertkwild
hi all,
got a cisco 3850 and one of the int is getting its uplink direct from the core switch and the other int is daisy chained to another edge switch which is going to another edge switch and then back to the core
i cant do a port channel as there not getting there uplinks direct from the core, so how can i make the int (directly attached to the core) the main one and this one wins all the time so to speak
thanks,
rob
8 Replies 8
Did you check below
Spanning tree vlan x port-priorty
Are this command allow ?
MHM
robertkwild
sorry i should had said both ports are trunked but one is directly uplinked to the core and the other link is going through other switches, so i want the one directly uplink to the core to win
Yes I get' you want trunk to core to be elect as FWD abd other port as BLK.
Am I right ?
MHM
robertkwild
yes @MHM Cisco World i want the uplink directly plugged in the core to win and the other uplink (daisy chain switches) to be the standby one IF the other one fails
Can I see
Show spanning tree interface details (both interface)
Let check it before go further
MHM
robertkwild
ok i see one int has priority 128.151 and the other int is 128.152
i got the above info from
sh spanning-tree interface Te2/1/3 and then after Te2/1/4
i imagine the heavy weight wins ie 128.152
Joseph W. Doherty
Just to confirm, these links are all L2 and a STP variant is being used?
Is the core the STP root switch?
Are all the links same bandwidths?
Any manual interface STP costing?
If answers are yes, yes, yes and no, the least number of link hops back to the root should be the preferred path.
Otherwise, we'll need more information about the topology, as STP sees it.
robertkwild
ah great so the int directly connected to the core switch has the least number ie 128.151 so i should be good
