11-30-2010 07:00 PM - edited 03-06-2019 02:17 PM
Hi Experts
I am Using Cisco 2350 Switches in my LAN. I want to enable port security on Cisco 2350 Switch. But port security commands are not supported under interface configuration. Cisco 2350 switch having only LAN Lite image. I wanted to know whether we can enable port security on 2350 switches.
If not supported , what is the solution to enable port security, as it is a mandatory requirement. Also wanted to know cisco road map plan to enable port security on 2350 switch
JMV
11-30-2010 07:47 PM
Hi JMV,
It is supported in your version of code you are running:
from the command reference guide:
spanning-tree portfast global config
spanning-tree portfast interface
Here is the reference guide:
Reza
11-30-2010 09:17 PM
Hi Reza,
My requirement is to use switchport port-security commands. I have to restrict the systems connecting to switch ports based on system MAC address. At I present I would like to restrict one MAC per port. If any violation happens, port has to be shutdown automatically.
I am doubt on the commands provided by you meet my requirement.
Expecting your advice
JMV
