Port Security Triggers with valid Mac Address during power on.
MARC FORESTER
I have 2 3560 switches that are running 12.2(25)SEE2. Port security is enabled on some of the ports. Whenever there is a power failure, when power is restored, 1 port on each switch goes to err-disabled. The mac address that causes this is a valid address for that port. Below is the configuration on one of the ports.
interface FastEthernet0/2
description CONNECTION TO PHONE AND PC[spanning tree disabled]
switchport trunk native vlan 10
switchport mode trunk
switchport port-security maximum 3
switchport port-security mac-address sticky
switchport port-security mac-address sticky 0018.b034.b392
switchport port-security mac-address sticky b4b5.2fcd.432a
switchport port-security mac-address sticky 0018.b034.b392 vlan 11
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
priority-queue out
mls qos trust dscp
auto qos voip trust
spanning-tree portfast
end
Feb 28 18:01:32 CST: %PM-4-ERR_DISABLE: psecure-violation error detected on Fa0/2, putting Fa0/2 in err-disable state
*Feb 28 18:01:32 CST: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address b4b5.2fcd.432a on port FastEthernet0/2.
*Feb 28 18:01:33 CST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/2, changed state to down
*Feb 28 18:01:34 CST: %LINK-3-UPDOWN: Interface FastEthernet0/2, changed state to down
priority-queue out
mls qos trust dscp
auto qos voip trust
end
This is the log entry for the error.
As you can see the mac address that caused the violation is configured for the port.
mahmoodmkl
Level 7
Level 7
i dont see any config related to vlan 11 under u r port.is vlan 11 is used for the pc
VLAN 11 is the Voice VLAN.
mahmoodmkl
Level 7
Level 7
then u havent defined it under the port
The port is a trunk port. I have this configuration on somewhere around 50 switches. This port and one other is what is having a problem.
