PortChannel packets output issues
Juraj Papic
Level 3
Level 3
We have a customer that has a 3800 port-channel (MTU 1500)  connected to a ISP, this ISP is sending MTU 9200. We only have one (1) interface enabled on the port-channel , when we enable the second interface we start getting output errors , and start with traffic issues.
Can this be because the MTU?
13 Replies 13
there is absolute issue of MTU mismatch
but the OUT error and traffic issue you need to check the STP.
share the output error you get
interface GigabitEthernet1/0/48
switchport trunk allowed vlan 14,16,20,21,61,108-110,160,221,801
switchport mode trunk
switchport nonegotiate
shutdown
channel-group 3 mode active
interface GigabitEthernet1/0/32
interface Port-channel3
Sorry posted a wrong interfaces.
spanning-tree portfast <<- this issue
also this which side ? and how you config port member of Port-channel ?
sorry posted the wrong interfaces I just did the update.
do you connect to only one ISP router o multi ISP routers ?
the ISP add two port to port-channel and when from your side try to enable the second port the issue arise ?
how your SW support this command
SW#show lacp neighbor detail
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 1 neighbors
Partner's information:
          Partner               Partner                     Partner
Port      System ID             Port Number     Age         Flags
FaX     MAC of ISP SW/R  0x8894           11s        FA
FaY    MAC of ISP SW/R  0x8893           11s        FA
Your Sw must see same MAC of ISP SW/R in both port otherwise the SW not recognize the PO.
If above is from your ISP side then
I see port g1/0/48 as passive but it config as active !!
shutdown
channel-group 3 mode active <<<--can you try add this command one more time.
The screen capture is from my side, I waiting to the ISP to send the config they have.
OK, port g1/0/48 connect to ISP, the ISP side use passive but ACTIVE->PASSIVE can work no problem
the issue is Your PORT not SYNC with ISP PORT.
Juraj Papic
Level 3
Level 3
What I have from the ISP port-channel is
load-interval 60
no lldp transmit
no lldp receive
no cdp enable
no vtp
