10-16-2025 08:06 AM
Sorry if this is a stupid question, but...
I've been using IE2000's in an application, and as those aren't available any longer, my company has switched to IE3000 switches.
I was putting the file for one of my IE2000's into the 3000 and it told me that "spanning-tree portfast edge" was invalid at the "edge" portion.
It looks from using "?" after the "portfast" that default is edge. But do I actually put "default" there? Or just leave it blank after "portfast" so that by default it's edge?
I'm somewhat confused is all...
Thanks!
Solved! Go to Solution.
10-16-2025 08:27 AM
10-16-2025 08:23 AM - edited 10-16-2025 08:26 AM
- @MartinNantus11364 Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3000/software/release/12-2_50_se/configuration/guide/ie3000scg/swstpopt.html#wp1031116
Leave it blank , which defaults to 'edge' (too)
M.
10-16-2025 08:27 AM
10-16-2025 09:00 AM
Thank you both gentlemen! I'll go with the "default" in hopes of confusing my boss. (^_^)
