Portfast won't go away!
rcoote5902_2
Level 2
Level 2
I have a 2950 switch in a remote site that has 2 3Com 8 port switches connected to it to secondary rooms.  I keep getting notified that these switches stop working.  I checked the 2950 and portfast was enabled, I issued "no spanning-tree portfast" on both ports, saved the config.
A couple of days later (after a power outage) the same thing happened.  I logged in, and "spanning-tree portfast" was back on both interfaces!
I've repeatedly removed this from the config and it keeps coming back.  I don't understand why.
Rob
Rajeev Sharma
Hi Rob,
Seems weired to me.
However:
Do you have port fast globally enabled?
What is the runnnign IOS on the box?
Raj.
Jon Marshall
Rob
Do you have "spanning-tree portfast default" configured in global configuration mode ?
If so then you need to use this command under the interface -
int
spanning-tree portfast disable
Jon
That's the funny thing...I don't have it enabled globally.
I added "spanning-tree portfast disable" to those two ports and it looks like it stuck after a reload.
Time will tell I suppose...
