Possibility of connecting Port-Channel to multiple physical port (gigabit/fasteth)
bsumardi1980
Good day eveyone,
Would you help to advise if below setup is possible? I did have try this on other brand of switches (Extreme) and it was working.
Thanks for your 5cents in advance !
Brgds
Ben
6 Replies 6
Leo Laohoo
Not possible unless the downstream switches are stacked to form a single logical switch (like the 3750 or 3850 or 2960S).
shine pothen
Level 3
Level 3
Adding to the above commands. if you are using Nexus 7 or any nexus devices then you can do this type of configuration which is called us VPC.
Hi Shine, it's non-nexus device. So it seems not feasilbe
Yes if it is non-nexus its not feasible.
Hope this answered your query.
Inayath
Thanks for all your information guys.
Thanks for this info. It was helfull to me as well.
regards
Fari
