Power inline auto max returning after reload
Tom Peeters
Dear/Dearest Support Community
I have a Cisco Catalyst WS-6509 switch with the following problem:
Each time the switch reloads, it adds this in the config to all my POE interfaces:
interface FastEthernet9/1
 no ip address
 switchport
 switchport access vlan xx
 switchport mode access
 power inline auto max 7000
end
After a reload I always have to perform a no power inline command, to remove the 7000 milli-watts limit.
Even tough I run the copy run start after this, each time it reloads, it shows up again.
Very annoying when you have POE devices connected which need more than 7000 milli-watts.
Any suggestions?
sh ver:
IOS (tm) c6sup2_rp Software (c6sup2_rp-PK9S-M), Version 12.2(18)SXD6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 17-Aug-05 18:56 by evmiller
Image text-base: 0x4002100C, data-base: 0x422F0000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PK9S-M), Version 12.2(18)SXD6, RELEASE SOFTWARE (fc1)
HSsec-CORE-S01 uptime is 3 hours, 25 minutes
Time since HSsec-CORE-S01 switched to active is 3 hours, 24 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 07:12:50 BRUSSELS Fri Oct 10 2014
System image file is "sup-bootflash:/c6k222-pk9s-mz.122-18.SXD6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID SCA05020CTK
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
9 Virtual Ethernet/IEEE 802.3  interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
252 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Leo Laohoo
Could be one of two things:  IOS bug or line card limitations.
