Power issue with 3850
S891
Level 2
Level 2
I am having power issue with my C3850-24XU-L  standalone switches. I have the Primary 1100 W power and an additional 715 W power. The total available power should be 1815 W but it is only showing 1265 W. When I remove the 1100 W power , it only leaves 165 W power and some of my PoE devices become powerless.
I do not have any power configuration (it is just default settings).
SW-W# show inventory
NAME: "Switch 1", DESCR: "WS-C3850-24XU-L"
PID: WS-C3850-24XU-L   , VID: V01  , SN: FCW193xxx
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-1100WAC    , VID: V01  , SN: LIT2038xxx
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-715WAC     , VID: V01  , SN: DCA2036xxx
SW-W#sh power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1          1265.0      275.3       989.7
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Te1/0/1   auto   on         30.0    Ieee PD             4     60.0
Te1/0/2   auto   off        0.0     n/a                    n/a   60.0
After removing the 1100 W power supply
1           165.0      159.2         5.8
                            (Watts)
Te1/0/3   auto   on         23.8    Ieee PD             4     60.0
Te1/0/4   auto   on         30.0    Ieee PD             4     60.0
Te1/0/5   auto   on         30.0    Ieee PD             4     60.0
Te1/0/6   auto   on         30.0    Ieee PD             4     60.0
Te1/0/7   auto   power-deny 0.0     n/a                 n/a   60.0
Te1/0/8   auto   power-deny 0.0     n/a                 n/a   60.0
Te1/0/9   auto   power-deny 0.0     n/a                 n/a   60.0
there are a couple of bugs where depending on your IOS version the values shown for the power supplies are incorrect. Which version are you running ?
WE are running on 16.3.6.
if possible try and upgrade to 3.2(2)SE.
