power supply
christina_neo
Level 2
Level 2
I would appreciate some advise on the following:
Background:
a cat6506 IOS 12.2(18).SXD3 is powered with redundant power supply(WS-CAC-1000W). currently, power supply 2 failed. From command, show power status all, it shows that the model of the power supply is WS-CAC-1000W. The power supply itself, it is printed 1300W. Cisco website(http://www.cisco.com/en/US/customer/products/hw/switches/ps708/prod_eol_notice0900aecd802e87bb.html) states that WS-CAC-1000W is EOL and should be replaced by WS-CAC-3000W.
1) With combination of WS-CAC-1000W and WS-CAC-3000W, is WS-CAC-3000W hot-swappable? should be yes?
2) When the power supply 2 is inserted, would it causes a downtime? should be no?
3) based on the website(http://www.cisco.com/en/US/customer/products/hw/switches/ps708/products_installation_guide_chapter09186a008020e0d3.html#wp1030022), I believe I am still able to get a power supply redundancy with both WS-CAC-1000W and WS-CAC-3000W? should be yes?
Christina
Roberto Salazar
Level 11
Level 11
A; YES
A: NO
A: YES, Any combination of PS types will operate together (including mixed AC and DC input types), though Cisco do not recommend this as a standard operating practice.
The key caveat for this situation is that the customer needs to treat the configuration as if both units are of the lower output rated type. (See that link you referenced).
Please rate all posts.
