ppp isdn connection
carl_townshend
Can anyone give me a definitive answer, that when connecting on isdn each end has to be on a common subnet ? a see people connecting to a number and just pushing a route to a number more or less !!
5 Replies 5
dpopli
Nope if you are using ISDN for WAN connection it has to be on different subnet
s-sheffield
The dialer interfaces should bo on the same subnet.
As it is a point-to-point link a 30 bit subnet mask (e.g. 255.255.255.252)is a good way to link them.
This is a network of 4 addresses with two usable (one for each end of the link).
Good address conservation practice
Stu
so do you have to have the interfaces on the same ip between them, or can you just point the traffic out, like a serial interface ? as I have seen this configuration on different models of router many of times
Carl
am unsure what you mean however I've done a basic setup of the dialer interfaces between two site as an example.
Obviously more config is needed (BRI/PRI int, chap etc).
Remote Office End
interface Dialer1
ip address 192.168.250.157 255.255.255.252
encapsulation ppp
dialer pool 1
dialer idle-timeout 1800
dialer string 0123456789
dialer max-call 1
dialer-group 1
priority-group 1
compress stac
ppp authentication chap
ip route 0.0.0.0 0.0.0.0 192.168.250.158
___________________________________________
Head Office End
interface Dialer1
bandwidth 64
ip address 192.168.250.158 255.255.255.252
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name Router_A
dialer string 9876543210
dialer-group 1
priority-group 1
compress stac
ip route 10.1.1.0 255.255.255.0 192.168.250.157 (route to the remote office LAN)
I hope this is what your asking about
Stu
Hi there, this is not what I mean, I basically mean that when you put an ip on the BRI or dialler interface, i.e both on a /30 subnet, do they have to be on an ip or can you use them like a serial where you dont need to be on the same ip but It can still see the other end ?
