PPP multilink not coming up on Serial interface / 3620 Router
latintrpt
I just finished setting up a bundle of (2) T1's in a multilink bundle and I'm having issues with one of the T1's not wanting to join the bundle.
The router I'm using on the remote office location is a 3620 router running code c3620-i-mz.121-1c.bin
The campus router which is a 7206 is setup the same exact way with multilink 240 and like I've said, serial 0/0 is joined to the bundle just fine, so we are running off one T1 connection.
The serial interface that is not working is: serial 0/1
Can you please help?  Thanks
Here is a show-run:
interface Multilink240
ip address 172.18.xxx.xxx 255.255.255.252
ip route-cache flow
ip ospf network point-to-point
service-policy output PhonesFirst
ppp multilink
multilink-group 240
interface Ethernet0/0
ip address 144.xx.xxx.xxx 255.255.255.128
ip route-cache flow
full-duplex
interface Serial0/0  ---> working
no ip address
encapsulation ppp
ip route-cache flow
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 240
interface Serial0/1  ---> not working
no ip address
encapsulation ppp
ip route-cache flow
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 240
ip flow-export source Multilink240
ip flow-export version 5
ip flow-export destination 144.xx.x.xx 2055
ip classless
ip route 0.0.0.0 0.0.0.0 172.18.xxx.xxx
no ip http server
show ppp multilink
Multilink240, bundle name is c7206_campusRouter
  1 lost fragments, 244 reordered, 0 unassigned, sequence 0xD02/0x2A093 rcvd/sen
t
  0 discarded, 0 lost received, 29/255 load
  Member links: 1 active, 1 inactive (max not set, min not set)
    Serial0/0
    Serial0/1 (inactive)
Remote-Router#sh int s0/0
Serial0/0 is up, line protocol is up
  Hardware is QUICC with integrated T1 CSU/DSU
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
     reliability 255/255, txload 29/255, rxload 44/255
  Encapsulation PPP, loopback not set
  Keepalive set (10 sec)
  LCP Open, multilink Open
  Closed: CDPCP
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 11:18:47
  Queueing strategy: fifo
  Output queue 0/40, 56102 drops; input queue 0/75, 0 drops
  5 minute input rate 269000 bits/sec, 51 packets/sec
  5 minute output rate 179000 bits/sec, 147 packets/sec
     413976 packets input, 308858382 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     3 input errors, 0 CRC, 3 frame, 0 overrun, 0 ignored, 0 abort
     4048570 packets output, 379509628 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Remote-Router#sh int s0/1
Serial0/1 is up, line protocol is down
  LCP Listen, multilink Closed
  Closed: CDPCP
  Last input 11:13:11, output 00:00:02, output hang never
  Last clearing of "show interface" counters 00:22:55
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
     0 packets input, 0 bytes, 0 no buffer
     32 input errors, 0 CRC, 32 frame, 0 overrun, 0 ignored, 0 abort
     296 packets output, 9472 bytes, 0 underruns
     0 output errors, 0 collisions, 73 interface resets
debug ppp negotiation
Nov  2 09:19:54: Se0/1 LCP: TIMEout: State Listen
Nov  2 09:19:54: Se0/1 LCP: O CONFREQ [Listen] id 34 len 28
Nov  2 09:19:54: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:19:54: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:19:54: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:19:56: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:19:56: Se0/1 LCP: O CONFREQ [REQsent] id 35 len 28
Nov  2 09:19:56: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:19:56: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:19:56: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:19:58: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:19:58: Se0/1 LCP: O CONFREQ [REQsent] id 36 len 28
Nov  2 09:19:58: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:19:58: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:19:58: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:00: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:00: Se0/1 LCP: O CONFREQ [REQsent] id 37 len 28
Nov  2 09:20:00: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:00: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:00: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:02: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:02: Se0/1 LCP: O CONFREQ [REQsent] id 38 len 28
Nov  2 09:20:02: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:02: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:02: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:04: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:04: Se0/1 LCP: O CONFREQ [REQsent] id 39 len 28
Nov  2 09:20:04: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:04: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:04: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:06: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:06: Se0/1 LCP: O CONFREQ [REQsent] id 40 len 28
Nov  2 09:20:06: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:06: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:06: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:08: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:08: Se0/1 LCP: O CONFREQ [REQsent] id 41 len 28
Nov  2 09:20:08: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:08: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:08: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:10: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:10: Se0/1 LCP: O CONFREQ [REQsent] id 42 len 28
Nov  2 09:20:10: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:10: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:10: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:12: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:12: Se0/1 LCP: O CONFREQ [REQsent] id 43 len 28
Nov  2 09:20:12: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:12: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:12: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:14: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:14: Se0/1 LCP: O CONFREQ [REQsent] id 44 len 28
Nov  2 09:20:14: Se0/1 LCP:    MagicNumber 0x1AA296FE (0x05061AA296FE)
Nov  2 09:20:14: Se0/1 LCP:    MRRU 1524 (0x110405F4)
Nov  2 09:20:14: Se0/1 LCP:    EndpointDisc 1 Local (0x130E01524E42432D526F75746
572)
Nov  2 09:20:16: Se0/1 LCP: TIMEout: State REQsent
Nov  2 09:20:16: Se0/1 LCP: State is Listen
latintrpt
anyone?
can you do sh controllers s0/0 and sh controllers s0/1
Alain.
Thanks for the reply, after moving S0/1 off the multilink group and setting as a point-to-point again, the interface came up.
If I move it back to the multilink group, it will go down again.
Here is the output you are requesting:
Router#show controllers s0/0
Interface Serial0/0
Hardware is Quicc 68360 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x60D82EC4, driver data structure at 0x60D89244
WIC interrupt reg = F
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x0006
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00C9CF00, Pending [CIPR]=0x00000000
Mask   [CIMR]=0xE0004400, In-srv  [CISR]=0x00000000
SDMA Registers:
[SDSR]=0x00, [SDAR]=0x01D2DB78, [SDCR]=0x0772
Command register [CR]=0x640
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0xA5FA
Port B [PBDIR]=0x0013FE, [PBPAR]=0x00000E
       [PBODR]=0x000000, [PBDAT]=0x03CC5C
Port C [PCDIR]=0x0002, [PCPAR]=0x000C
       [PCSO]=0x00A0,  [PCDAT]=0x0F0D, [PCINT]=0x0001
Receive Ring
        rmd(3C010420): status 9000 length 37 address 1D19EE4
        rmd(3C010428): status 9000 length 2E address 1D184E4
        rmd(3C010430): status 9000 length AA address 1D191E4
        rmd(3C010438): status 9000 length 2F address 1D1C5E4
        rmd(3C010440): status 9000 length 30 address 1D1ABE4
        rmd(3C010448): status 9000 length 33 address 1D18B64
        rmd(3C010450): status B000 length 5E2 address 1D19864
Transmit Ring
        tmd(3C010458): status 5C00 length 12E address 1D56694
        tmd(3C010460): status 5C00 length 34 address 1D2BB6A
        tmd(3C010468): status 5C00 length 32 address 1D25BCA
        tmd(3C010470): status 5C00 length 2D address 1D4DC94
        tmd(3C010478): status 5C00 length 34 address 1D48CCA
        tmd(3C010480): status 5C00 length 32 address 1D2DB4A
        tmd(3C010488): status 7C00 length 244 address 1C02694
SCC GENERAL PARAMETER RAM (at 0x3C010C00)
Rx BD Base [RBASE]=0x420, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x458, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x18008240, BD Ptr [RBPTR]=0x430
Tx State [TSTATE]=0x18800311, BD Ptr [TBPTR]=0x458
SCC HDLC PARAMETER RAM (at 0x3C010C38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=39
Nonmatch Addr Cntr [NMARC]=0
RNBC-Router#show controllers s0/1
Interface Serial0/1
idb at 0x60D8BE40, driver data structure at 0x60D921C0
SCC Registers:
SDMA Registers:
[SDSR]=0x00, [SDAR]=0x01C04A80, [SDCR]=0x0772
       [PAODR]=0x0000, [PADAT]=0xAAFC
Receive Ring
        rmd(3C010490): status 9000 length 77 address 1D234A4
        rmd(3C010498): status 9000 length 1FB address 1D227A4
        rmd(3C0104A0): status 9000 length DB address 1D21AA4
        rmd(3C0104A8): status 9000 length 9B address 1D20DA4
        rmd(3C0104B0): status 9000 length C6 address 1D1FA24
        rmd(3C0104B8): status 9000 length 36 address 1D1F3A4
        rmd(3C0104C0): status B000 length 103 address 1D21424
Transmit Ring
        tmd(3C0104C8): status 5C00 length 34 address 1D4BA94
        tmd(3C0104D0): status 5C00 length 2E address 1C04A54
        tmd(3C0104D8): status 5C00 length 244 address 1D4C5D4
        tmd(3C0104E0): status 5C00 length 34 address 1C00714
        tmd(3C0104E8): status 5C00 length 34 address 1C005D4
        tmd(3C0104F0): status 5C00 length 34 address 1C014D4
        tmd(3C0104F8): status FC00 length 34 address 1D347AA
SCC GENERAL PARAMETER RAM (at 0x3C010D00)
Rx BD Base [RBASE]=0x490, Fn Code [RFCR]=0x19
Tx BD Base [TBASE]=0x4C8, Fn Code [TFCR]=0x19
Rx State [RSTATE]=0x19008240, BD Ptr [RBPTR]=0x4B0
Tx State [TSTATE]=0x19000348, BD Ptr [TBPTR]=0x4D0
SCC HDLC PARAMETER RAM (at 0x3C010D38)
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=6
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=58075
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
QUICC SCC specific errors:
17645 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
1554 aborted short frames
