PPPoE on Vlan 1
Alex Mac
Hi folks,
I wonder if the vlan 1 interface can be configured with PPPoE.
By looking at the PPPoE session I see it's stuck into PADI-sent (PADISNT) phase
GW877W#show pppoe session
1 client session
Uniq ID PPPoE RemMAC Port Source VA State
SID LocMAC VA-st
N/A 0 0000.0000.0000 Vl1 Di0 N/A PADISNT
0000.0000.0000
and it is what I see (debug pppoe packets)
*Mar 30 04:35:33.169: pppoe_send_padi:
         FF FF FF FF FF FF 00 1A E2 18 99 87 88 63 11 09
         00 00 00 0C 01 01 00 00 01 03 00 04 85 34 1A 48 ...
I do see the packet on VLAN1 but on FastEthernet 2 (switchport mode access vlan 1) the counter seems to increment for other packets present on the cable so I cannot tell if indeed the PADI goes out the Fa2 interface.
Am I missing anything from the configuration here below?
GW877W#sh run int di0
Building configuration...
Current configuration : 258 bytes
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname ******
ppp chap password 0 ******
ppp direction callout
ppp pap sent-username ****** password 0 ******
ppp multilink
end
GW877W#sh run int vlan 1
Current configuration : 85 bytes
interface Vlan1
no ip address
pppoe enable
GW877W(config-if)#pppoe-client dial-pool-number 1
%The preferred method for configuring a pppoe-client is on an ethernet sub-interface
end
GW877W#sh run int fa2
Current configuration : 65 bytes
interface FastEthernet2
description CONNECTION TO PLANET
end
GW877W#sh vl
GW877W#sh vlan-
GW877W#sh vlan-switch
VLAN Name Status Ports
1 default active Fa2
20 WAN_ACCESS_1 active Fa0
30 WAN_ACCESS_2 active Fa1
100 LAN active Fa3
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
20 enet 100020 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
GW877W#show run | sec vpdn
vpdn enable
vpdn-group EDPNET_THROUGH_PLANET
request-dialin
protocol pppoe
GW877W#
Does anyone see any errors in the config above?
Or how should it be done?
Thanks in advance,
Alex
0 Replies 0
