PPPoE over QinQ configuration
phailaquy
Hi all
Now I configure PPPoE network for my Customer. I run PPPoE QinQ for my Customer
With outer Vlan 10 and inner vlan 100
Here my Config:
BRAS:
bba-group pppoe GOI01
virtual-template 1
vendor-tag circuit-id service
sessions per-mac limit 3
sessions per-vlan limit 1500
interface Loopback1
ip address 11.1.1.1 255.255.255.255
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback1
peer ip address forced
peer default ip address pool GOI01
ppp mtu adaptive
ppp authentication pap npc
ppp authorization npc
ppp accounting npc
ip local pool GOI01 100.10.10.1 100.10.10.254
int Gi 1/1.401100
encapsulation dot1q 401 second-dot1q 100
!! 10 is the OuterVLAN and 100 is Customer VLAN
Pppoe enable group GOI01
AGG
int GI 1/1
description to BRAS
switchport mode dot1q-tunnel
switchport mode trunk
int GI 1/1
description to POP Switch
SWITCH POP
int Gi 1/2
description Conect to AGG Switch
switchport access vlan 10 >> OuterVLAN in QnQ
int GI 1/3
description Connect to SW Customer
SW Customer
int GI 1/3
description Connect to POP SWITCH
Int g1/1
Description **connect to ROUTE PPPoE Client**
Switchport mode access
Switchport access vlan 10
I test call pppoe successful with PPPoE over VLAN and PPPoE over Ethernet but PPPoE over QinQ is not work.
I debub ppp negotiate but I can’t see any log. I think had some problem with QinQ configuration.
Pl help me.
Thank you very much
0 Replies 0
