Priority queuing some questions
sarahr202
Level 5
Level 5
Hi everybody.
I am watching this great Video on qos. Got few questions on Priority queuing.  Based on the  video lecture, we have 4 quietus in priority queuing system
They are:
High, medium, normal, ( i forgot the last one lol)
Anyway let say I have already classified my traffic as
traffic1,
traffic2,traffic3
traffic 4.
I want traffic 1 to use High priority, traffic 2 should use " Medium" priority queue.
How can I map these traffic classes to queues ?
thanks for your help
Have a great weekend.
daniel.dib
Level 7
Level 7
Priority queueing is a legacy type of queueing that uses four queues. They are high, medium, normal and low. Priority queueing is prone to queue starvation because it will entirely empty one queue before moving on to the next. That means that if there are constantly packets in the high queue then the other queues will never get served.
You can assign either protocols or use access-lists to map traffic to the different queues in the following way:
R1(config)#priority-list 1 protocol http medium
R1(config)#access-list 100 permit tcp host 1.1.1.1 host 2.2.2.2 eq 22
R1(config)#priority-list 1 protocol ip high list 100
Then assign it to an interface:
R1(config)#int f0/0
R1(config-if)#priority-group 1
R1(config-if)#do sh int f0/0
FastEthernet0/0 is administratively down, line protocol is down
  Hardware is Gt96k FE, address is c200.2bcc.0000 (bia c200.2bcc.0000)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Half-duplex, 10Mb/s, 100BaseTX/FX
  Last input never, output never, output hang never
  Queueing strategy: priority-list 1
  Output queue (queue priority: size/max/drops):
     high: 0/20/0, medium: 0/40/0, normal: 0/60/0, low: 0/80/0
     0 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     0 packets output, 0 bytes, 0 underruns
The default is to allow 20 packets into high, 40 into medium, 60 into normal and 80 into low. The queue sizes can be tuned in the following way:
R1(config)#priority-list 1 queue-limit ?
  <0-32767>  High limit
R1(config)#priority-list 1 queue-limit 5 ?
  <0-32767>  Medium limit
R1(config)#priority-list 1 queue-limit 5 20 ?
  <0-32767>  Normal limit
R1(config)#priority-list 1 queue-limit 5 20 50 ?
  <0-32767>  Lower limit
R1(config)#priority-list 1 queue-limit 5 20 50 100
I would not expect to see this type of queuing today but it doesn't hurt to know it for reference.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
Thanks Daniel.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I just want to emphasis what Daniel already noted, which is in PQ each queue has absolute priority over any queues "below" it, which means, for example, "low" queue packets will only be transmitted when there are no "high", "medium" or "normal" packets waiting to be transmitted. So as Daniel also noted, PQ can easily "starve" lower queues of all bandwidth.
BTW, since PQ is just looking at queue contents, it also doesn't consume much device resource for its management.
