Priority vs. Bandwidth Commands
Hieu Cao
Level 4
Level 4
Questions:
1. If I set aside 30% of T1 bandwidth using Priority command and it actually uses 20% of it, does the remaining 10% get distributed into the rest of the Classes in QoS? or does Bandwith command do so?
I am unclear if either one of them will do it.
Greatly appreciated any feedback or TID to reference it.
Thanks!
Hieu
Any unused bandwidth is shared among other classes. That applies to both LLQ and CBWFQ. In your scenario, the 10% bandwidth will be available for other classes defined in the policy map.
Sundar
Sundar
Thanks, Sundar! I've also found the info from Cisco QoS FAQs..
" Although the bandwidth guarantees provided by issuing the bandwidth and priority commands have been described with words like "reserved" and "bandwidth to be set aside", neither command implements a true reservation. Meaning, if a traffic class is not using its configured bandwidth, any unused bandwidth is shared among the other classes. "
Hieu
