Private VLAN limitation
nedian123
I am planning to use private vlans for customer webservers in DMZ & CAT6509 is having an L2 trunk(port channel) to a non-Cisco Firewall. Since there is a limitation not to configure private vlans using LaCP/EtherChannel, how would I define a promiscuous port in this scenario so that private vlan to primary vlan translation could happen...
In this case can L3 switching would happen b/w private vlans ??
Any help & best practice suggesstion would be appreciable.
Note: setup details & C6509 config attached.
Akhtar
didyap
Level 6
Level 6
Here is the URL for the Private VLAN configuration and limitation which will help you :
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/pvlans.html
