Problem authenticating over PPP
phillip.ireland
Community Member
Morning
I have a Cisco 877 ADSL Router which is experiancing problems connecting to my ISP.
According to my ISP the router is connecting just isnt trying to authenticate(Log in)
Below is the current config:
Router#
Router#sh ru
Building configuration...
Current configuration : 1235 bytes
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address x.x.x.x x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxx
ppp chap password 7 xxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
On the front of the router i have a solid CD light and solid power light.
8 Replies 8
cadet alain
post result of debug ppp authentication command.
Regards.
Alain.
I am new to cisco would you be able to tell me what to do!
Can you access CLI? I suppose so as you have posted the running config.
if so then in privileged mode( #) issue the following command:  debug ppp authentication
then try to connect again and you'll see debug messages on the screen, copy paste on this forum
Regards.
Alain.
try to connect by rebooting the router or can i force the retry
Sorry guys
not rebooting but you can enter the debug command and then  try this:
int dial0
no encap ppp
encap ppp
Run the debug command and then ran the no encap ppp and encap ppp command.
Still nothing on screen, doesn't look like its even attempting to authenticate
are you connected with console cable or by telnet?
Problem is now fixed
I setup the ATM0.1 point-to-point interface DOH!
Worked first time
