Problem booting up a Cisco 2811 Router
a.ajiboye
A company just bought a Cisco 2811 router which I am installing for them. Each time I boot up this router I get the following error message:
Read only ROMMON initialized
boot:cannot open "flash"
boot:cannot determine the first executable file name on device "flash"
C2811 processor with 262144KB of main memeory
Does any one have a clue as to what the problem is and how I can rectify it?
Prashanth Krishnappa
Probably you have are missing an image in the flash or have a misconfigured bootvariable.
When the router is in ROMMON mode, issue a "dir flash:" and check to see what files you have in flash.
If you have a file which starts with "c2800.....", boot from it using "boot flash:c2800....."Once the router boots up, post output of dir flash:, sh bootvar, sh run.
If there is no image in flash, you will need to use XMODEM to recover.
scottmac
Level 10
Level 10
Is there a flash card (CF) in the reader?
Try re-seating it.
If you have a CF reader on your PC, you can read and write to it (I believe the larger CFs use a FAT32 format).
Good Luck
Scott
