Problem changing Vlan 1 ip address
LEN SNEED
I have a 3750 stack that connects to a 3560 at another site.  The are both on the inside of our network and basically a switch to switch connection.  The switchports are in vlan 901.  When I telnet from the 3750 to the 3560 and attempt to change the 3560's vlan 1 ip address I lose connectivity and can only get it back by going to the site and consoling into the 3560 to change the vlan 1 ip address back.  The 3750 vtp mode is server and the remote 3560 is vtp transparent.  Any ideas why this is happening?
Len.
mlund
Level 7
Level 7
Hi Len
The reason this is not working is because the vlan1 is not forwarded between the switches.
As I described in my previous contribution You have to have vlan1 forwarded between the switches.
The config You have now are only connecting vlan901, by making the g0/22 and g4/0/1 a trunkport and allowing vlan 1 and 901 will solve the problem.
Or You can connect a new cable between the switches and forward vlan1 that way.
Or, You can give the vlan1 interface on 3560 an ip address that is not overlapping with other neetworks.
/Mikael
18 Replies 18
Reza Sharifi
Hi Len,
Is Vlan 1 being used for management?  If you use vlan 1 IP address to telnet and once you login in change the IP address, then you will lose connection.
Reza
Thanks for the reply Reza,
I was actually telnetted into 3560 via vlan 905.
When the vlan 1 ip was changed not only did the telnet connection drop all network traffic throught the 3560 stopped.
So, the PC that you telent from is in vlan 905 or in vlan 1?
The telnet was made from 10.1.5.38 on 3750 vlan1 to 3560 10.255.254.2 which is vlan905.
3750:
int g4/0/1
switchport access vlan 901
switchport mode access
int vlan1
ip address 10.1.1.1 255.255.0.0
ip helper-address 10.1.5.20
int vlan 901
ip address 10.255.255.1 255.255.255.0
3560:
int g0/21
switchport access vlan 905
int g0/22
int vlan1
ip address 170.53.73.56 255.255.255.0
int vlan 901
ip address 10.255.255.2 255.255.255.0
int vlan 905
ip address 10.255.254.2 255.255.255.0
Tried to change the 3560 vlan1 ip to 10.1.255.73 255.255.0.0
No you didn't.  You telnet from 3750 VLAN 1 to 3560 VLAN 1 and bridged to VLAN 905.
So when I am on terminal server 10.1.5.38 which connects to the 3750 vlan 1 and telnet to 10.255.254.2 (vlan 905)
on the 3560 I am really telnetting to the 3560 vlan 1 bridging to 905.  Then when I changed the vlan 1 ip I would lose my connection but why would all network traffic on other vlans stop?
Good question.  Are you running IP Routing IOS or just IP Base?
IP routing.
Why vlan 1 on the 3750 is on one subnet and on the 3560 a different subnet?
int vlan1
3560:
int vlan1
The 3560 used not to be on the inside of the firewall.  When we installed ASA's recently the 3560 was then configured to be on the inside interface.  The different vlan1 ip's were left the way they were prior to the ASA installs.
Reza,
Any further ideas on this issue?
Len.
Hi Len
Because we haven't seen the whole config of the switches this is a guess of what happens.
You telnet from 10.1.5.38 to 10.255.254.2 this means your traffic flows to 3750 10.1.1.1 (defaultgatewy I guess),
via routingstatements in 3750 pointing to 3560.
The return traffic goes from 3560 towards 3750, via routing and out to Your terminalserver
When You change the address on 3560 to 10.1.255.73 the return traffic towards 10.1.5.38 is now seen as local connected on 3560,
and the 3560 will just put the returntraffic out on the vlan1 interface.
Then vlan 1 must be connected through a trunk between switches, otherwise the traffic will stop.
If the above is not correct, Perhaps You can share the complete configuration.
/Mikael
Mikael,
Below are the outputs of the show ip route and show ip eigrp topology commands.  Two things that I have noticed are:
1- On the core 3750 the following are present for the show ip route:
             10.0.0.0/8 is variably subnetted, 104 subnets, 3 masks
    C       10.1.0.0/16 is directly connected, Vlan1
   On the remote 3560 just has '10.0.0.0/8 is variably subnetted, 56 subnets, 2 masks'.
2- On the remote 3560 the vlan 1 ip and the eigrp router-id are both 170.53.73.56
Would these have any impact when the 170.53.73.56 ip is changed to 10.1.255.73 on the 3560?
Remote 3560:
remote-3560#sh ip rout
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.255.255.1 to network 0.0.0.0
     170.53.0.0/16 is variably subnetted, 6 subnets, 3 masks
S       170.53.230.0/24 [1/0] via 10.255.254.1
S       170.53.32.0/19 [1/0] via 10.255.254.1
S       170.53.75.0/24 [1/0] via 10.255.255.1
C       170.53.73.0/24 is directly connected, Vlan1
S       170.53.72.12/32 [1/0] via 10.255.255.1
S       170.53.64.0/19 [1/0] via 10.255.254.1
     70.0.0.0/30 is subnetted, 1 subnets
D       70.63.126.128 [90/3072] via 10.255.252.1, 4d17h, Vlan902
     172.31.0.0/24 is subnetted, 1 subnets
D       172.31.255.0 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.9.0.0/16 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.103.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.102.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.101.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
C       10.255.253.0/24 is directly connected, Vlan903
C       10.255.252.0/24 is directly connected, Vlan902
C       10.255.255.0/24 is directly connected, Vlan901
C       10.255.254.0/24 is directly connected, Vlan905
C       10.255.251.0/24 is directly connected, Vlan904
D       10.4.0.0/16 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.5.0.0/16 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.113.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.112.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.52.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.53.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.52.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.104.6.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.104.7.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.109.15.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.104.10.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.109.14.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.104.11.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.104.8.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.109.11.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.15.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.104.14.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.109.10.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.14.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.104.15.0/24 [90/3072] via 10.255.251.1, 4d17h, Vlan904
D       10.109.22.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.23.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.22.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.255.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.193.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.192.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.192.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.203.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.202.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.202.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.163.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.162.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.161.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.162.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.109.161.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.171.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.172.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.109.171.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.173.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.172.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.182.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.109.181.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.183.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.182.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.105.181.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
D       10.109.191.0/24 [90/3072] via 10.255.253.1, 4d17h, Vlan903
D       10.105.191.0/24 [90/3072] via 10.255.252.1, 4d17h, Vlan902
S*   0.0.0.0/0 [1/0] via 10.255.255.1
MCH-3560#sh ip eigrp topology
EIGRP-IPv4 Topology Table for AS(100)/ID(170.53.73.56)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 10.4.0.0/16, 1 successors, FD is 3072
        via 10.255.251.1 (3072/2816), Vlan904
P 10.109.52.0/24, 1 successors, FD is 3072
        via 10.255.253.1 (3072/2816), Vlan903
P 10.104.15.0/24, 1 successors, FD is 3072
P 10.105.172.0/24, 1 successors, FD is 3072
        via 10.255.252.1 (3072/2816), Vlan902
P 10.105.181.0/24, 1 successors, FD is 3072
P 10.109.14.0/24, 1 successors, FD is 3072
P 170.53.32.0/19, 1 successors, FD is 28160
        via Rstatic (28160/0)
P 170.53.64.0/19, 1 successors, FD is 28160
P 10.105.255.0/24, 1 successors, FD is 3072
P 10.109.191.0/24, 1 successors, FD is 3072
P 10.5.0.0/16, 1 successors, FD is 3072
P 10.105.192.0/24, 1 successors, FD is 3072
P 10.109.22.0/24, 1 successors, FD is 3072
P 10.105.193.0/24, 1 successors, FD is 3072
P 170.53.75.0/24, 1 successors, FD is 28160
P 10.105.103.0/24, 1 successors, FD is 3072
P 10.104.10.0/24, 1 successors, FD is 3072
P 10.105.52.0/24, 1 successors, FD is 3072
P 10.104.6.0/24, 1 successors, FD is 3072
P 10.109.161.0/24, 1 successors, FD is 3072
P 10.109.171.0/24, 1 successors, FD is 3072
P 10.109.162.0/24, 1 successors, FD is 3072
P 170.53.72.12/32, 1 successors, FD is 28160
P 10.105.22.0/24, 1 successors, FD is 3072
P 10.105.163.0/24, 1 successors, FD is 3072
P 172.31.255.0/24, 1 successors, FD is 3072
P 10.105.23.0/24, 1 successors, FD is 3072
P 10.105.112.0/24, 1 successors, FD is 3072
P 10.255.252.0/24, 1 successors, FD is 2816
        via Connected, Vlan902
P 10.9.0.0/16, 1 successors, FD is 3072
P 70.63.126.128/30, 1 successors, FD is 3072
P 10.255.254.0/24, 1 successors, FD is 2816
        via Connected, Vlan905
P 10.105.102.0/24, 1 successors, FD is 3072
P 170.53.230.0/24, 1 successors, FD is 28160
P 10.255.253.0/24, 1 successors, FD is 2816
        via Connected, Vlan903
P 10.255.251.0/24, 1 successors, FD is 2816
        via Connected, Vlan904
P 10.105.203.0/24, 1 successors, FD is 3072
P 10.255.255.0/24, 1 successors, FD is 2816
        via Connected, Vlan901
P 10.109.181.0/24, 1 successors, FD is 3072
P 10.104.14.0/24, 1 successors, FD is 3072
P 0.0.0.0/0, 1 successors, FD is 28160
P 10.105.182.0/24, 1 successors, FD is 3072
P 10.104.8.0/24, 1 successors, FD is 3072
P 10.109.11.0/24, 1 successors, FD is 3072
P 10.104.11.0/24, 1 successors, FD is 3072
P 10.105.101.0/24, 1 successors, FD is 3072
P 10.109.192.0/24, 1 successors, FD is 3072
P 10.105.162.0/24, 1 successors, FD is 3072
P 10.109.172.0/24, 1 successors, FD is 3072
P 10.105.191.0/24, 1 successors, FD is 3072
P 10.105.15.0/24, 1 successors, FD is 3072
P 10.105.53.0/24, 1 successors, FD is 3072
P 10.105.171.0/24, 1 successors, FD is 3072
P 10.105.202.0/24, 1 successors, FD is 3072
P 10.105.173.0/24, 1 successors, FD is 3072
P 10.109.15.0/24, 1 successors, FD is 3072
P 10.105.183.0/24, 1 successors, FD is 3072
P 10.105.113.0/24, 1 successors, FD is 3072
P 10.109.10.0/24, 1 successors, FD is 3072
P 10.104.7.0/24, 1 successors, FD is 3072
P 10.109.182.0/24, 1 successors, FD is 3072
P 10.109.202.0/24, 1 successors, FD is 3072
P 10.105.161.0/24, 1 successors, FD is 3072
P 10.105.14.0/24, 1 successors, FD is 3072
remote-3560#sh ip eigrp topology
Core 3750:
Core-3750G-1#sh ip route
Gateway of last resort is 10.255.1.2 to network 0.0.0.0
D EX    170.53.230.0/24 [170/28416] via 10.255.255.2, 4d17h, Vlan901
D EX    170.53.32.0/19 [170/28416] via 10.255.255.2, 4d17h, Vlan901
D EX    170.53.75.0/24 [170/28416] via 10.255.255.2, 4d17h, Vlan901
S       170.53.72.12/32 [1/0] via 10.255.1.2
D EX    170.53.64.0/19 [170/28416] via 10.255.255.2, 4d17h, Vlan901
S       170.53.75.35/32 [1/0] via 10.255.1.2
D       70.63.126.128 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       172.31.255.0 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.111.0/24 is directly connected, Vlan111
C       10.101.109.0/24 is directly connected, Vlan109
C       10.101.108.0/24 is directly connected, Vlan108
D       10.9.0.0/16 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.103.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.107.0/24 is directly connected, Vlan107
D       10.105.102.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.106.0/24 is directly connected, Vlan106
D       10.105.101.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.255.253.0/24 [90/3072] via 10.255.255.2, 4d17h, Vlan901
C       10.101.103.0/24 is directly connected, Vlan103
D       10.255.252.0/24 [90/3072] via 10.255.255.2, 4d17h, Vlan901
C       10.101.102.0/24 is directly connected, Vlan102
C       10.2.1.0/24 is directly connected, Vlan12
C       10.101.101.0/24 is directly connected, Vlan101
D       10.255.254.0/24 [90/3072] via 10.255.255.2, 4d17h, Vlan901
D       10.255.251.0/24 [90/3072] via 10.255.255.2, 4d17h, Vlan901
D       10.4.0.0/16 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.5.0.0/16 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.113.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.112.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.113.0/24 is directly connected, Vlan113
C       10.101.112.0/24 is directly connected, Vlan112
C       10.101.69.0/24 is directly connected, Vlan69
C       10.101.68.0/24 is directly connected, Vlan68
C       10.101.67.0/24 is directly connected, Vlan67
C       10.101.66.0/24 is directly connected, Vlan66
C       10.101.92.0/24 is directly connected, Vlan92
C       10.101.91.0/24 is directly connected, Vlan91
C       10.101.89.0/24 is directly connected, Vlan89
C       10.101.88.0/24 is directly connected, Vlan88
C       10.101.87.0/24 is directly connected, Vlan87
C       10.101.86.0/24 is directly connected, Vlan86
C       10.101.39.0/24 is directly connected, Vlan39
C       10.101.38.0/24 is directly connected, Vlan38
C       10.101.37.0/24 is directly connected, Vlan37
C       10.101.36.0/24 is directly connected, Vlan36
D       10.109.52.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.53.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.52.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.15.0/24 is directly connected, Vlan15
C       10.101.14.0/24 is directly connected, Vlan14
D       10.104.6.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.104.7.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.9.0/24 is directly connected, Vlan9
D       10.109.15.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.104.10.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.14.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.104.11.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.104.8.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.11.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.15.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.104.14.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.10.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.14.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.104.15.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.22.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.23.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.22.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.255.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.193.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.192.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.203.0/24 is directly connected, Vlan203
C       10.101.202.0/24 is directly connected, Vlan202
C       10.101.201.0/24 is directly connected, Vlan201
D       10.109.192.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.203.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.202.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.202.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.193.0/24 is directly connected, Vlan193
C       10.101.192.0/24 is directly connected, Vlan192
D       10.105.163.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.162.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.161.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.173.0/24 is directly connected, Vlan173
C       10.101.172.0/24 is directly connected, Vlan172
C       10.101.171.0/24 is directly connected, Vlan171
D       10.109.162.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.161.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.171.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.172.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.171.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.163.0/24 is directly connected, Vlan163
C       10.101.162.0/24 is directly connected, Vlan162
D       10.105.173.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.161.0/24 is directly connected, Vlan161
D       10.105.172.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.191.0/24 is directly connected, Vlan191
D       10.109.182.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.181.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.183.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
--More--                           D       10.105.182.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.105.181.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
D       10.109.191.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.101.183.0/24 is directly connected, Vlan183
C       10.101.182.0/24 is directly connected, Vlan182
C       10.101.181.0/24 is directly connected, Vlan181
D       10.105.191.0/24 [90/3328] via 10.255.255.2, 4d17h, Vlan901
C       10.255.1.0/29 is directly connected, Vlan900
C       10.101.153.0/24 is directly connected, Vlan153
C       10.101.152.0/24 is directly connected, Vlan152
C       10.101.151.0/24 is directly connected, Vlan151
S*   0.0.0.0/0 [1/0] via 10.255.1.2
DC-3750G-1#sh ip eigrp topology
EIGRP-IPv4 Topology Table for AS(100)/ID(10.255.255.1)
P 10.4.0.0/16, 1 successors, FD is 3328
        via 10.255.255.2 (3328/3072), Vlan901
P 10.109.52.0/24, 1 successors, FD is 3328
P 10.104.15.0/24, 1 successors, FD is 3328
P 10.105.172.0/24, 1 successors, FD is 3328
P 10.105.181.0/24, 1 successors, FD is 3328
P 10.109.14.0/24, 1 successors, FD is 3328
P 170.53.32.0/19, 1 successors, FD is 28416
        via 10.255.255.2 (28416/28160), Vlan901
P 170.53.64.0/19, 1 successors, FD is 28416
P 10.105.255.0/24, 1 successors, FD is 3328
P 10.109.191.0/24, 1 successors, FD is 3328
P 10.5.0.0/16, 1 successors, FD is 3328
P 10.105.192.0/24, 1 successors, FD is 3328
P 10.109.22.0/24, 1 successors, FD is 3328
P 10.105.193.0/24, 1 successors, FD is 3328
P 170.53.75.0/24, 1 successors, FD is 28416
P 10.105.103.0/24, 1 successors, FD is 3328
P 10.104.10.0/24, 1 successors, FD is 3328
P 10.105.52.0/24, 1 successors, FD is 3328
P 10.104.6.0/24, 1 successors, FD is 3328
P 10.109.161.0/24, 1 successors, FD is 3328
P 10.109.171.0/24, 1 successors, FD is 3328
P 10.109.162.0/24, 1 successors, FD is 3328
P 170.53.72.12/32, 0 successors, FD is Inaccessible
P 10.105.22.0/24, 1 successors, FD is 3328
P 10.105.163.0/24, 1 successors, FD is 3328
P 172.31.255.0/24, 1 successors, FD is 3328
P 10.105.23.0/24, 1 successors, FD is 3328
P 10.105.112.0/24, 1 successors, FD is 3328
P 10.255.252.0/24, 1 successors, FD is 3072
        via 10.255.255.2 (3072/2816), Vlan901
P 10.9.0.0/16, 1 successors, FD is 3328
P 70.63.126.128/30, 1 successors, FD is 3328
P 10.255.254.0/24, 1 successors, FD is 3072
P 10.105.102.0/24, 1 successors, FD is 3328
P 170.53.230.0/24, 1 successors, FD is 28416
P 10.255.253.0/24, 1 successors, FD is 3072
P 10.255.251.0/24, 1 successors, FD is 3072
P 10.105.203.0/24, 1 successors, FD is 3328
P 10.109.181.0/24, 1 successors, FD is 3328
P 10.104.14.0/24, 1 successors, FD is 3328
P 0.0.0.0/0, 0 successors, FD is Inaccessible
P 10.105.182.0/24, 1 successors, FD is 3328
P 10.104.8.0/24, 1 successors, FD is 3328
P 10.109.11.0/24, 1 successors, FD is 3328
P 10.104.11.0/24, 1 successors, FD is 3328
P 10.105.101.0/24, 1 successors, FD is 3328
P 10.109.192.0/24, 1 successors, FD is 3328
P 10.105.162.0/24, 1 successors, FD is 3328
P 10.109.172.0/24, 1 successors, FD is 3328
P 10.105.191.0/24, 1 successors, FD is 3328
P 10.105.15.0/24, 1 successors, FD is 3328
P 10.105.53.0/24, 1 successors, FD is 3328
P 10.105.171.0/24, 1 successors, FD is 3328
P 10.105.202.0/24, 1 successors, FD is 3328
P 10.105.173.0/24, 1 successors, FD is 3328
P 10.109.15.0/24, 1 successors, FD is 3328
P 10.105.183.0/24, 1 successors, FD is 3328
P 10.105.113.0/24, 1 successors, FD is 3328
P 10.109.10.0/24, 1 successors, FD is 3328
P 10.104.7.0/24, 1 successors, FD is 3328
P 10.109.182.0/24, 1 successors, FD is 3328
P 10.109.202.0/24, 1 successors, FD is 3328
P 10.105.161.0/24, 1 successors, FD is 3328
P 10.105.14.0/24, 1 successors, FD is 3328
Hmmm ... If VLAN 1 and 905 have an IP address, what is the default-gateway IP address?  Is this in the same subnet as VLAN 1?
