Problem collecting log from CAT 4500 with Syslog-ng
fgravalos
I have a Syslog Server with Syslog-ng 3.6 witch receives logs from different Cisco SW and RT from all over my Network.
Configuration is pretty simple:
/etc/syslog-ng/syslog-ng.conf
source s_net {
        tcp(ip(0.0.0.0) port(514));
        udp(ip(0.0.0.0) port(514));
destination d_host-specific {
file("/var/log/remotos/$HOST/$YEAR/$MONTH/$HOST-$YEAR-$MONTH-$DAY.log");
log {
        source(s_net);
        destination(d_host-specific);
All SW and RT have a very similar configuration if not exactly the same:
logging trap debugging
logging XX.XX.XX.XX
But here's the thing, Syslog-ng receives logs from most of the devices but Cisco Cat4500.
All the documentation I've found about configuring Cisco CAT4500 to send logs is for simple Syslog, and not Syslog-ng.
I've can't manage to receive logs from a CAT4500 but I do from several WS-C296 and other devices which are in the same network.
I've tried to add a filter with the Host IP to no avail:
filter f_SW1_MSS_SRVs { host( "XX.XX.XX.XX" ); };
destination df_SW1_MSS_SRVs { file("/var/log/remotos/SW1_MSS_SRVs.log"); };
log { source( s_net ); filter( f_SW1_MSS_SRVs ); destination ( df_SW1_MSS_SRVs ); };
Don't know if I'm missing something in the CAT4500 configuration or if it's the Syslog Server.
Any help would be apreciated.
what do you have configured on the 4500 under 'logging facility' ? Check the link below for available keywords:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sg/configuration/guide/conf/log.html#wp1084288
"logging facility" is set to "local7"
Heres the output of "show loggin":
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 16662 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 16662 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level debugging, 16650 message lines logged
Logging to XX.XX.XX.XX (udp port 514, audit disabled,
authentication disabled, encryption disabled, link up),
16612 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
