problem configuring ospf on ring with 3560
I have a problem with the OSPF configuration on 3560 switch, i delete a link between two switch and y lost the comunication , i add a topology and the sh run of 3 3560 switchs.........can you help me??
BR
David
Mark Malone
looks to be miss configured , 10.0.2.1 exists on 2 interfaces , f2 on r1 and r2
5 Replies 5
Mark Malone
My apology, , i put r1 in r2 again , the correct r2 is here....
ok so to be sure here
when its all up and working you have an ospf to each neighbour and each router knows about every subnet correct ?
if you drop a link traffic doesn't go the other way ? if that's the case something may be up at software level if routing tables are ok , changes the ios version
does anything show in the logs for ospf changes other than the link you dropped
hi david,
can you share
#sh ip ospf database
#sh ip ospf neighbor
i send you the ospf comands result
