Problem Flexible Netflow on port-channel
I am facing a problem with Netflow and port-channels.
i'm using a Catalyst 3850 on IOS 16.12.05b.
Everything works on physical ports without "port-channel"
But for the interfaces grouped in port channel, no traffic is detected :
Cache type: Normal (Platform cache)
Cache size: 10000
Current entries: 0
Flows added: 0
Flows aged: 0
Can you help me ?
My setup is basic:
flow record goelastic_input
match transport source-port
match transport destination-port
match ipv4 protocol
match ipv4 tos
match ipv4 ttl
match interface input
match flow direction
match datalink vlan input
match ipv4 source address
match ipv4 destination address
collect counter bytes long
collect counter packets long
flow exporter exp_goelastic_input
destination XX.XXX.XXX.XXX
source Loopback0
transport udp 2055
flow monitor ipv4_netflow_input
cache timeout active 60
Ok i found the problem.
the problem comes from nbar
we cannot apply on the same interface netflow and nbar
pman
please post netflow configuration under the interfaces.
In addition:
  • Flexible NetFlow configurations applied on one of the Layer 3 port-channel member port will also be applied across all other member ports within the same device. For devices configured either as part of stack or with StackWise Virtual, Cisco recommends to configure the Flexible NetFlow on the port-channel interface.
  • Flexible NetFlow is not supported on the Layer 2 port-channel interface, but is supported on the Layer 2 port-channel member ports.
  • Multiple Flexible Netflow configurations are supported either on port-channel interface or port-channel member ports but not on both.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-12/configuration_guide/nmgmt/b_1612_nmgmt_3850_cg/configuring_flexible_netflow.html
Hi thanks for your respons,
here is the configuration of my port channels:
interface Port-channel43
switchport mode trunk
switchport nonegotiate
And the configuration of a physical interface:
interface GigabitEthernet1/0/11
channel-group 43 mode active
ip nbar protocol-discovery
To listen to netflow traffic, I just apply the flow monitor to the physical interfaces (member of a port channel) :
#interface Gi1/0/1
#ip flow monitor .... input
it's supposed to work, I don't understand the error
Thanks for your help
