problem in boot the switch 2960
master.mohammed
Community Member
HI
I have switche cisco 2960
When you boot it displays the following message
So that the green lights are working well
Please help me in solving the problem
5 Replies 5
Leo Laohoo
There's a possibilty the baud rate of your HyperTerminal client and the switch do not match.
Of very normal to be 9600
These are the settings to your hyperterminal.
9600 baud rate
No parity
8 data bits
1 stop bit
No flow control
And if these settings don't work then try to adjust the baud rate higher or lower until you tried all of them.
I tried changing each setting for speed, parity, etc. and connecting after each change - none of them got any output.
Use a different client/computer/laptop.
