Problem in Pulling Crashinfo file from Cisco7609
Sri v
A quite long my cisco 7609 router got rebooted by generating crashinfo file on both RP and SP. Please refer below
Show sup-bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .. image        9BD41DAD 2BDE6D4   30 45475412 Dec 11 2008 17:06:01 +05:30 s72033-psv-mz.122-18.SXD7b.bin
2   .. unknown      A6AEEEA1 2BDEB98   29     1091 Oct 8 2011 00:05:07 +05:30 diaginfo_mod1_20111007-183507
3   E. unknown      FFFFFFFF 2C505C0   29   465320 Feb 4 2015 23:02:39 +05:30 crashinfo_20150204-230239-IST
19593792 bytes available (45942208 bytes used)
Show bootflash:
1   E. unknown      FFFFFFFF   EBA04   29   440708 Feb 4 2015 23:02:39 +05:30 crashinfo_20150204-230239-IST
From the output it clears that both the crashinfo got corrupted and denoted with error flasg "E". So in this case I need to use
RP - > more /error bootflash:<filename>
Result : success
SP -> more /error sup-bootflash:<filename>
Result : Failed with error "%Error opening sup-bootflash:crashinfo_20150204-230239-IST (File not found)"
Can anyone suggest how to fetch the crashinfo file from SP ??
Leo Laohoo
more bootflash:crashinfo_20150204-230239-IST
Hi Leo,
No that's fails, and says error opening crashinfo file. Moreover I am able to fetch the RP(bootflash) crashfile by using more /error bootflash:
but unable to fetch SP(sup-bootflash:) by using more /error sup-bootflash:crashfile.
Pls suggest
