Problem radius
peguayapero
I have 30 switches, and in one of them this presenting the message: "RADIUS server 172.23.11.5:1645,1646 is not responding", the other ones don't have that problem.
I annex log of the switch.
sh ver
sh conf
What could be happening?
steve.busby
Level 5
Level 5
Look at your ACS failed authentication logs to determine why it's failing.
If you remove the 172.23.11.5 host, does this switch authenticate against the other servers? Check your shared key on both the ACS server (172.23.11.5) and your switch. Reenter the key on both devices to ensure there is no hidden space at the end.
Steve
i forget log
When you have multiple authentication servers configured, Cisco IOS uses a "radius server deadtime" feature.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_command_reference_chapter09186a00800d9bf2.html#xtocid182015
Your IOS is doing exactly what it's designed to do:
RADIUS server 172.23.11.5:1645,1646 is not responding.
RADIUS server 172.23.11.5:1645,1646 has returned.
You need to go to the logs on the ACS server and see why this device is failing authentication.
Steve
