Problem routing between 2 network segments with Cisco 3925
itcjdh
I have a new Cisco 3925 router.  I have 2 network segments 10.0.1.X with net mask 255.255.255.0 and 10.0.2.x wo\ith netmask 255.255.255.0.
I have an internet gateway router at 10.0.1.21.
I have set GBethernet 0/0 to 10.0.1.1 / 255.255.255.0 and GBethernet 0/1 to 10.0.2.1 / 255.255.255.0.
I have set a static route 0.0.0.0 / 0.0.0.0 to 10.0.1.21 for gateway of last resort.
When I setup a workstation on the 10.0.2.X segment at 10.0.2.100 wirh a gateway of 10.0.2.1,  I can ping 10.0.2.1 and 10.0.1.1 but can not ping anything else on the 10.0.1.X network or on the internet.
When I am connedted to the console port on the router I can ping 10.0.1.1 and 10.0.2.1 and 10.0.1.21 and any address in the internet
but I can not ping 10.0.2.100.
When I am on a network connected to the 10.0.1.x network af 10.0.1.100 I can ping 10.0.1.1 and 10.0.2.1 and 10.0.1.21 and anywhere on the internet but can not ping 10.0.2.100 or any other address on the 10.0.2.x network other than 10.0.2.1.
What Do I need to do on the 3925 to get to all address on each segment and to get to the 10.0.1.21 gateway from the 10.0.2.x addresses?
5 Replies 5
acampbell
John
Sounds like you need to add a route on 10.0.1.21
10.0.2.0/24 via 10.0.1.1 as the return path.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
itcjdh
I added 10.0.2.0 255.55.255.0 via 10.0.1.1 as a route on 10.0.1.21 and it had no effect on any sration.  Also that wouild not evplain why the console could not piing anything on the 10.0.1.x segment but 10.0.1.21.
have you tried disabling the firewall on the hosts not responding ?
Alain
firewalls are not enabled and also If I change one of their ip addresses and put them on the same segment they can ping each other.
John,
What do the interfaces on the router connect to ?
How do the PCs connect at layer 2.
Alex.
