Problem routing with one switch between several vlans
JbOne
Hi everybody !
I create one project with cisco packet tracer, i added several switches with several Vlans and one laptop.
The configuration is the following one :
ROUTER 1:
Building configuration...
Current configuration : 571 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 10.100.59.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.59
encapsulation dot1Q 59
no ip address
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
ip classless
ip flow-export version 9
SW1 :
Current configuration : 1549 bytes
version 12.2(37)SE1
hostname SW-01
ip routing
spanning-tree mode pvst
interface FastEthernet0/23
switchport mode trunk
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan30
mac-address 0007.ec5a.ea01
ip address 192.168.30.1 255.255.255.0
interface Vlan59
mac-address 0007.ec5a.ea02
ip address 10.100.59.7 255.255.255.0
interface Vlan210
mac-address 0007.ec5a.ea03
ip address 192.9.210.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.100.59.10
ip route 192.168.30.0 255.255.255.0 192.168.30.1
SW 2:
Current configuration : 1312 bytes
version 12.2
hostname Switch
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/22
interface Vlan1
no ip address
shutdown
interface Vlan30
mac-address 0060.472e.6001
ip address 192.168.30.11 255.255.255.0
ip default-gateway 192.168.30.1
SW 3:
version 12.2
hostname Switch
interface Vlan1
no ip address
shutdown
interface Vlan30
LAPTOP:
IP : 10.100.59.12
MASK : 255.255.255.0
GATEWAY : 10.100.59.10
When i want ping from Laptop the SW1 it does not work :
ping : 10.100.59.12 => 192.168.30.1
Can you help me please ?
Thank you so much.
Best regards
Mark Malone
whats doing the layer 3 switch or the router ?
you have a few problems there starting with the router the interface is setup wrong , it looks like your trying to setup R&S , If your trying to do router on stick you should look at this as a guide below
router sub-interface is setup wrong , router needs routes as well to get back to the devices
all vlans must be specified at layer 2 as well
default-gateways should be used on layer 2 switches , default-routes on layer
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
Hi Mark Malone,
Thank you for your answer, i watch and I hold you informed.
Thanks.
Hi Mark Malone,
I just tried but i can't find the problem, i changed the switchs of L2 to L3 and modify the configuration but always the same.
The topology is this :
The router "Router_MTR" for the moment is not used, the switch "SW-Gateway" is the gateway for my project.
You would have an idea my problem ?
Thanks for your help
