Problem to display logging
jmartinez
Community Member
Hello to all,
if i perform a "show logging" i can get this:
cme#show log
Syslog logging: enabled (11 messages dropped, 3 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 23510 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 5081 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty514(208)
    Buffer logging:  level debugging, 19 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
No active filter modules.
    Trap logging: level notifications, 11649 message lines logged
        Logging to 10.0.0.204  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              11649 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
Log Buffer (4096 bytes):
i need to see the 5081 messages that are logged in "Monitor logging" what is the correct way in order to display this messages?
thanks and regards.
milan.kulik
Level 11
Level 11
IMHO, issuing "term monitor" will start displaying the messages on your terminal screen on-line.
But no way to display a message history.
See logging monitor at  http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_09.html#wp1066253
and terminal monitor at http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf003.html#wp1019329
HTH,
Milan
